kz900 oil pressure gauge
- sean5775
16 Apr 2008 15:23 #206966
by sean5775
1972 Kawasaki H2-750 Triple Mach IV
1976 Kawasaki KZ900 A4
1981 Kawasaki KZ440 LTD
1981 Kawasaki KZ750LTD-4
1983 Suzuki GS650 Tempter
1981 Yamaha Virago XV920
kz900 oil pressure gauge was created by sean5775
Just wondering if anyone knows if there is a place to hook up a gauge on a KZ900 to check the oil pressure. Not a permanent gauge just something temporary.
- Jeff.Saunders
16 Apr 2008 17:00 - 16 Apr 2008 17:01 #206987
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic kz900 oil pressure gauge
right hand side of the engine cases, just behind the cylinder block - there's an aluminum bolt plugging an oil takeoff...
...and don't expect to see very high numbers... 2-3 PSI when warm...
Z1 Ent on Facebook,
Last edit: 16 Apr 2008 17:01 by Jeff.Saunders.
