- Thank you received: 6
Bigger cams needed for my 1000
- kawtoy
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- racer54
- Thank you received: 114
- rattler
- Thank you received: 2
- kawtoy
- Zedone
- Thank you received: 14
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- racer54
- APE Jay
- Banned
- Thank you received: 58
You also might have to clearance the head next to the lifter bores so the cams have room to rotate. Put the cams in and slowly turn them til high part of lobe is ready to run onto the bucket. If the cam is big enough and might hit the head, you will see where it needs to be "relieved" so there is enough room.
410s do need this.
Jay
- 79MKII
- Love Them Kaws!
- Thank you received: 43
Hi kawtoy, don't forget to grind the "+" castings off of the inside of your valve cover for camlobe clearance. Maybe you already know about this, cheers, Doug
Do you know if the exhaust side of the cover needs clearanced too? I only have the "+" castings on the intake side. It looks like my old cover was clearanced for all 8 lobes but I don't want to do the exhaust side if I don't have to. I'm getting ready to send a cover to be chromed and want to grind it first. I have .425 cams and the head was clearanced.
The Kaw List:
- Zedone
1977 KZ1000A1
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
