TDC Piston stops
- KZG1
TDC Piston stops
14 Apr 2008 12:34
Degreeing cams with adjustable sprockets calls for using a piston stop to locate TDC. Is having the piston stop threaded completely (sitting flush) against the the cyclinder head needed to get TDC? Looking over my video from Web cam it doesn't say.
Thanks
Thanks
80 KZ1000G1
84 GPZ1100
Honda Trail 70
"You can't get paid if you don't go to work"
84 GPZ1100
Honda Trail 70
- BSKZ650
Re: TDC Piston stops
14 Apr 2008 12:47
The reason for the piston stop is so you can find true TDC, all it has to do is stop the piston at some point before TDC, mark the degree wheel, rotate in opposite direction until it stops, mark the degree wheel, divide the number in half, gives you true TDC.
all the stop does in "stop " the piston, just make sure the stop does not move during rotation
77 ltd1000, current rider
76 kz900, just waiting
- KZG1
14 Apr 2008 13:14
thanks.
80 KZ1000G1
84 GPZ1100
Honda Trail 70
84 GPZ1100
Honda Trail 70
- KZG1
14 Apr 2008 13:29
Using a degree wheel is the most accurate method in cam timing, what about ignition timing? Im using a Dyna2000. The timing marks on the crank dont line up TDC. Making it hard to accuretly set timing. Has anyone experienced this? and what are some things that can be done. Hope this make sence.
Max
Just checked plugs, has to be timing for my engine over heating
Max
80 KZ1000G1
84 GPZ1100
Honda Trail 70
84 GPZ1100
Honda Trail 70
14 Apr 2008 14:33
KZG1 wrote:
Am using Dyna S and am unfamilar with Dyna 2000, or maybe mis-reading the question. But believe the T mark or TDC mark is not used for ignition timing. And that the F marks are used for ignition timing, at least with the Dyna S. If the Dyna 2000 uses the T marks for ignition timing, I gladly stand corrected.
Good Luck!
Using a degree wheel is the most accurate method in cam timing, what about ignition timing? Im using a Dyna2000. The timing marks on the crank dont line up TDC. Making it hard to accuretly set timing....Just checked plugs, has to be timing for my engine over heating
Good Luck!
- BSKZ650
14 Apr 2008 14:34
dont quote me on this, but I think the mark is set for the proper amount of timing advance, not a TDC mark
- tuxedotito
17 Apr 2008 17:57 - 17 Apr 2008 18:03
BSKZ650 wrote:
That's it..., the "F" mark on advancer unit, at idle speed, should line up with the mark on the crankcase.
Above 3500RPM, the two little parallel lines to the right of the "F" mark, should center on the crankcase mark.
Hope it helps.
Hope it helps.
1981 GPz1100, Wiseco 1170 Kit, BS34 carbs; #40 Pilot and #140 Main, UNI Filters, APE main and cylinder studs, DYNA S, DYNA Coils, and lots of hours. Working towards Megasquirt/Turbo one day!!!
Ft. Lauderdale, FL
Ft. Lauderdale, FL
Last edit: 17 Apr 2008 18:03 by tuxedotito. Reason: typo
- tuxedotito
17 Apr 2008 17:59 - 17 Apr 2008 18:07
Page 2...note the relative positions of #6(Advanced Timing Mark) at low speed, and at high speed.
Good luck;)
Good luck;)
Ft. Lauderdale, FL
Ft. Lauderdale, FL
Last edit: 17 Apr 2008 18:07 by tuxedotito.
- Rickman
Re: Dyna2000 was Re:TDC Piston stops
17 Apr 2008 21:12
KZG1 wrote:
The actual ignition timing is controlled by the dyna2000 box. It's just taking a reference off the crank sensor, I'm not sure what it has to do with TDC. There should only be one way to attach the black aluminum timing rotor to the crankshaft. (If I remember correctly.) Set the timing statically by turning the engine with a wrench to see that the LED on the box (set to test mode) lights up exACTLY when your selected timing mark gets to the reference. Which timing mark? Check the manual; my 1171 cc 10.5:1 2-valve motor uses the "40" for 40 degrees btdc. First set the rotation of the base of the sensor to align the right-hand sensor, then adjust the left side magnet so that the LED lights up when the other "40" is at the reference.Using a degree wheel is the most accurate method in cam timing, what about ignition timing? Im using a Dyna2000. The timing marks on the crank dont line up TDC. Making it hard to accuretly set timing. Has anyone experienced this? and what are some things that can be done. Hope this make sence.
Max
Could it be running lean?Just checked plugs, has to be timing for my engine over heating
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
