BROKEN cam chain guide
  • guitargeek
  • guitargeek's Avatar Topic Author
  • Elitist, arrogant, intolerant, self absorbed.
13 Apr 2008 17:03
#206197
Broken, not worn out.
Anybody ever seen this before? I have no idea how long it's been like this, probably as long as I've had the bike. I've put a lot of miles on it, and it never complained...
I found the little piece in the oil pan.
What could cause such a thing? Seems pretty catastrophic, and I'd expect equally grave results elsewhere in the engine, but everything else looks good so far...
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • Skyman
  • Skyman's Avatar
Re: BROKEN cam chain guide
13 Apr 2008 18:34
#206219
Yep. I've seen it.
When I opened up the engine on my '78 KZ1000, I saw the same thing. From what I've read elsewhere, it is a fairly common sight on some models with about 40K miles.
West Linn, OR
  • Saki Jockey
  • Saki Jockey's Avatar
13 Apr 2008 19:29
#206236
Were either of you running a manual adjuster?
Rob A.
550 A4
GTA,
Ontario, Canada
  • guitargeek
13 Apr 2008 19:30
#206237
No, the stock cross-wedge automatic tensioner.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
14 Apr 2008 01:05
#206299
Don't know about the 750 (still haven't cracked the motor on mine, yet...but I fully expect to find what you have:) ), but every KZ1000A motor I have cracked has those guides virtually worn to nubs...and this is on some bikes with low mileage (<25,000 miles)...I suspect is is a function of age, wear, heat, and long-term exposure to petroleum products. And some of those bikes with those 'nubs' were still running.:ohmy:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • coppertales
  • coppertales's Avatar
14 Apr 2008 09:30
#206369
Yep, seen that twice, costs me 8 valves each time....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
