What is this????
  • ultegra
  • ultegra's Avatar Topic Author
What is this????
13 Apr 2008 15:49
#206175
There is oil leaking around this area on my bike. What is it???
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: What is this????
13 Apr 2008 16:03
#206179
That's where the tach cable hooks up.
What year model bike do you have?
Add that info to your signature in your Profile.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • markerdown
  • markerdown's Avatar
13 Apr 2008 16:13
#206183
Looks like possibly your tach drive. There are kits available to replace the seals so she no more leaky;) ...........markerdown
The Need for Speed Never Dies
\\\\\\\'75 Z2 750
\\\\\\\'76 KZ900
\\\\\\\'73 Z1 900 restoration project
\\\\\\\'73 Cuda 340 restoration project
2018 Z900RS
  • otakar
  • otakar's Avatar
13 Apr 2008 17:47
#206213
That is where the tach would normaly go but it is apperantly not machined, so the bike which that head came from has an electronic and not a mechanical tach.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • ultegra
13 Apr 2008 18:40
#206222
This isn't the head on my bike but i have an electronic tach on my bike. It appears it has been blocked off and is leaking around that area. I have 79 1000 could anyone tell me where I can get this part?
I am trying to sell the bike and want to fix it before I sell it. Here are a couple pics.
  • Mark Wing
  • Mark Wing's Avatar
13 Apr 2008 20:23
#206262
Real nice, I like it.
Yorba Linda Cal.
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
13 Apr 2008 20:24
#206263
im not to sure about the part, but i really like that bike. i just got a tingly feeling seeing it.
Welcome to KZR
  • bill_wilcox100
  • bill_wilcox100's Avatar
13 Apr 2008 21:37 - 13 Apr 2008 21:41
#206275
Up front, I have never had this problem. :unsure:
However, have you considered taping it and inserting a threaded plug. Your local auto shop should be able to recommend a plug, probably brass, and preferably with an integrated O-ring or at least Teflon tape.
Best of success and let us know how you eventually solve this. :)
PS
That's a real beauty. Too hard a ride for my body these days but its still a class act.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 13 Apr 2008 21:41 by bill_wilcox100.
  • Becker
  • Becker's Avatar
  • The Doctor Will Rise Again
13 Apr 2008 23:11
#206286
If you do use teflon tape make sure that you leave 2-3 treads exposed on the end. Teflon tape isn't actually supposed to be used to seal things but it will do the trick. the reason you don't want to cover the whole bolt however is because some of that tape will break off and could get lodged in the filter or other small holes used to lubricate the engine. In hydraulics your not supposed to use it at all for this reason but you can generally get away with it if you don't tape the whole bolt.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • ultegra
14 Apr 2008 05:24
#206305
thanks for all the info everyone
