Bike temp
  • KZG1
  • KZG1's Avatar Topic Author
Bike temp
13 Apr 2008 09:17
#206109
I've always heard that KZ's ran hotter than most bikes. A good example is my bro's 83 GS750E, after a long ride in east texas we stopped for a smoke and i happened to touch my valve cover. it was hotter than hell so hot that i could wet my finger and it would instintly burn off (sizzle). same thing was done to the GS and not near as the temperture.
Is that the norm for the KZ.
This is my only KZ, nothing to compare to
80 KZ1000G1
84 GPZ1100
Honda Trail 70
"You can't get paid if you don't go to work"
  • Beatpoet
  • Beatpoet's Avatar
Re: Bike temp
13 Apr 2008 10:53 - 13 Apr 2008 10:53
#206120
make sure you're not running lean - pull the plugs and check.
Hopefully, there are no clogs in the oiling system as well.:ohmy:
Last edit: 13 Apr 2008 10:53 by Beatpoet.
  • bountyhunter
  • bountyhunter's Avatar
Re: Bike temp
14 Apr 2008 09:22
#206363
Not mine.
  • KZG1
Re: Bike temp
14 Apr 2008 13:18
#206450
would changing to a cooler plug help in reducing heat, im using B8ES now.
80 KZ1000G1
84 GPZ1100
Honda Trail 70
  • bountyhunter
Re: Bike temp
14 Apr 2008 13:39
#206455
No, it just changes the temperature of the spark plugs tip.
Re: Bike temp
14 Apr 2008 14:41
#206467
KZG1 wrote:
... 83 GS750E, after a long ride...valve cover..was hotter than hell so hot that i could wet my finger and it would instintly burn off (sizzle). same thing was done to the GS and not near as the temperture. Is that the norm for the KZ. This is my only KZ, nothing to compare to
Was either bike running an oil cooler? :unsure:
  • RonKZ650
  • RonKZ650's Avatar
Re: Bike temp
14 Apr 2008 14:52
#206469
Hot is a term that has a different meaning for every person. Too me, yes they run hot. I could take my KZ1000 on one of those long rides and after riding a couple miles the cylinder was already dang hot. This always worried me so I added a cooler. I can't say I noticed any difference, but set my mind at ease a little. The motorcycle never missed a beat so it must have been normal temps.
