blown head gasket
- ran429
- Master of FREE rides!
The left side #1-#2 are leaking oil from the head, might be from the sitting so long, bad running and more sitting.
I just believe that the top end is in need of repair and I want to put all my time into the cop bike rebuild instead and just ride the 750 not work on it anymore.
It runs good at idle, but when i get on the throttle while riding it (under a load) boggs down and has no power. I just rejetted to 70 primary mains and 140 secondary mains, it ran great! now its sat again for a little less than a month (started a couple times here and there) but its back to no power again.
- Beatpoet
This is fun! While you're at it you can think about oversized cams, high comp. pistons, head shaving, porting/polishing, oversized valves, performance valve springs, etc.
If there's oil coming out of the head (not the valve cover?) gasket,I'd just take it apart and rebuild it.
It doesn't take that long. If you haven't done it before, pair up with someone who has to give you tips along the way... Fun levels increase dramatically when working with someone more experienced
- ran429
After starting the bike, I revved it up all the way and shut the key off W_O_T when i pulled the new plug out shortly after this a huge plume of smoke followed the plug and looked like a smoker being opened to turn the meat.
Cylinder was saturated with oil before i replaced bad plug with a good one.
- ran429
I really dont want to rebuild it quite yet, I want to repair the COP bike first so i atleast have two wheels to play on while the other one is down.Rebuild the top end.
- ran429
All back to normal, I guess i need to stop idling it here and there and just RUN it WOT down the road a few times to warm it up and cycle the old fuel out of carbs.
The plugs are getting carbon fouled fast, faster now that i rejetted to 70/130 mains. 2 turns out on the adjusters.
- ran429
Doing 60, threw it down a couple gears to get way ahead of the cages and twisted the gas. looked down and the needle was pegged at 85. I quickly got off it as i was not in a good spot to be doing that.
However i slowed to 65 and then proceeded to take the next exit to another highway and went two more exits (5 miles) to Green Valley road.
Stopped at the meat store for a Coke and looked the bike over again, all seemed fine except all the goo seeping out my head gasket.
Wiped it off and headed home.
when i got home i snapped this photo with my phone of the head gasket area on #1.
Heres the bike all by its lonesome at the store. Yes, i set my hemet there it didnt fall off.
- Thank you received: 2098
- ran429
Holy crap i forgot!With the history reported, I would also check for possibility of liquid black goo weeping past the exhaust gasket and blowing everywhere else from there.
I only have one compression sleeve on the #1!
That (i hope) is it.
Thanks for reminding me.
- bountyhunter
- Thank you received: 337
so, after going out and starting it again today, i notice #4 isnt firing proper. I take out the plug and insert a new one and it fires now.
I'll bet your valve seals are hosed.
It could also be blowing by the rings, but if the rings are bad you should see blue smoke when you accelerate hard.
- mariozappa
- Thank you received: 8
My B1 sat for a long time and leaked a little from there, but stopped once I started riding it most of the time.
Just wipe it off and ride it like you stole it.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
