1976 kz900 bored to 1035. What carbs?
- BARNEYHYPHEN
30 Jan 2006 16:53
Just about to rebuild my 76 kz900 with 1015 block honed to 70.25mm, new pistons & rings. Everything else stock. Also rinning 26mm carbs.
IfI want to make the most of the bigger bore, what size carbs would I be best advised to use. Thanks.
- wireman
- RomSpaceKnight
Re: 1976 kz900 bored to 1035. What carbs?
30 Jan 2006 17:29
28's are stock carbs for many KZ's. The 26's where a pollution control device, I think. Go for a set of 28's at least. If you can get a set of 29mm smoothbores, do it. Your 26's will work fine, but for some more oomph bigger carbs are the ticket.
