TACHOMETER FAILED - READS 0RPM - PLEASE HELP
- KOOL RYDER
- KZ 650B2 / KZ 1000E
11 Apr 2008 07:53 #205686
by KOOL RYDER
Hello fellow KZ RIDERS:
I just had a tune up on my KZ650B (1978).
I had the valves adjusted and shortly after my Tachometer failed.
Does anyone know how to troubleshoot this problem. Clymer says that you have to remove the tach pinion when removing the exhaust cam (which was done by the service technician) to service the valves.
Anyways it worked for about 10 - 15 miles after getting the bike back and then the tach failed. (Now sits at 0RPM)
I am dissapointed, because I really like to wind the bike out and used the tach quite a bit. The bike really kicks into life after 5000 RPM and now I am afaraid that my riding style will be comprimised as a result of losing the tach.
Any ideas would help.
RIDE SAFE SO YOU CAN RIDE AGAIN TOMMOROW.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
TACHOMETER FAILED - READS 0RPM - PLEASE HELP was created by KOOL RYDER
1978 KZ650B
1979 KZ1000ST
- mariozappa
- Thank you received: 8
11 Apr 2008 08:05 #205687
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic TACHOMETER FAILED - READS 0RPM - PLEASE HELP
Check to make sure both ends of the tach cable are screwed in and tight.
If they are screwed in, remove the end from the tach. Start the engine and you should see the cable spin.
If it does not spin, undo the engine end of the cable and start the engine, you should see the little nub spinning.
That should help narrow it down.
1977 KZ650C1
- BSKZ650
- Thank you received: 14
11 Apr 2008 08:06 #205690
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic TACHOMETER FAILED - READS 0RPM - PLEASE HELP
Welcome to the site,,, did you check the cable to see if its broke,if it is good then pull the drive out and inspect it, it shouldnt be that hard to get back in
- rdgrnr
11 Apr 2008 08:50 #205704
by rdgrnr
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
Replied by rdgrnr on topic TACHOMETER FAILED - READS 0RPM - PLEASE HELP
Check to make sure the tech reinstalled and tightened the tach holder washer thingy. If he didn't, the tach drive will pop out enough for it to stop working. You will notice it right away as there most likely be oil oozing out.
Personally, after checking the cable and looking at the end while running (as previously mentioned), I would pull the tach drive out and inspect it. Make sure the gear is not chewed up. If it is, let me know as I have one that you can have.
By the way, there is plenty of experience here that you will soon gain enough knowledge to do most everything on your own, and you won't need to waste your money on techs that just got out of school. They don't know these bikes like we do, and most likely never will.
So search past threads and the database here, and you will most likely find whatever you need. If not, then ask as there are many here that have been there, done that, and know what they are talking about...So...Welcome:)
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- KOOL RYDER
11 Apr 2008 10:11 #205732
by KOOL RYDER
1978 KZ650B
1979 KZ1000ST
Replied by KOOL RYDER on topic TACHOMETER FAILED - READS 0RPM - PLEASE HELP
Do I just pull the tach drive out with the Allen Key bolt?
1978 KZ650B
1979 KZ1000ST
- KOOL RYDER
11 Apr 2008 10:15 #205735
by KOOL RYDER
1978 KZ650B
1979 KZ1000ST
While i am new i am trying to figure out how i can communicate dircetly with you. To learn more about how to pull the tach drive. I am sure that the guy did not reinstall it properly.
1978 KZ650B
1979 KZ1000ST
- rdgrnr
11 Apr 2008 11:45 - 11 Apr 2008 11:49 #205762
by rdgrnr
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
Ok,
Remove the holding screw and holder. There is a seal and seal ring that will come with the drive(don't lose these).
The housing will come out with a little persuasion, but be patient as there is an o-ring midway that is holding it in place. Once that is removed, the gear is then accessable. The gear might come out with the housing, or it might not.
If it doesn't, turn it counter-clockwise and it should the come out. This really should be done with the head/valve cover removed so that you can visibly see the process, but it doesn't have to be. Having the cover removed allows you to loosen the cam to ease this process, plus it helps you learn more of the workings of the DOHC process.
Hope this helps..
If you need to directly chat with someone, just click on "PM" button, and you can send a direct message to that user.
One other thing, go to your profile and update to show what you have and where you are.
It saves a lot of time of having to explain what your ride is when you have questions..and also there might be a member close to you that can assist with problems.
We like pics here...
Hope this helps..
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
Last edit: 11 Apr 2008 11:49 by rdgrnr.
- RonKZ650
- Thank you received: 240
11 Apr 2008 11:55 #205763
by RonKZ650
Replied by RonKZ650 on topic TACHOMETER FAILED - READS 0RPM - PLEASE HELP
It's pretty rough to not install the drive correctly. If it's not falling off the front of the engine gushing oil out of the vacant hole it's on there correctly.
