No Power - KZ440
- gaillarry
Problem is the engine has no power beyond 2nd gear. At WOT between gears the bike hardly accelerates. I did notice the chain has about 4" of play.
Engine runs and sounds good with good throttle response at idle. Would the loose chain cause the poor acceleration?
1977 KZ1000
1985 Gpz750
- wiredgeorge
If the bike sounds like it is increasing in rpms but not accelerating as it should, perform a clutch cable adjustment per a factory service manual.
- bountyhunter
- Thank you received: 337
No, it can't. As George said, check to see if you hear the RPM's spin up without much acceleration because that means the clutch is slipping. If the bike just has weak power when you try to stand on it, that would be a whole different thing.Looking a buying an 81 KZ440 for my niece. Bike is in great condition with 19,000 kms. The owner has problems shifting beyond 2nd gear. I adjusted the clutch mech on the sprocket cover and the bike now shifts into all 6 gears. Although its hard to down shift.
BTW, when my clutch springs were getting tired and the clutch started to slip, it did it WORST in low gears when I tried to accelerate and if I lightened up on the throttle it would hook up. In higher gears it didn't slip much that I could hear.
As for slipping clutch, I have heard (not personally seen) that some bike clutches get slippy when somebody uses the wrong auto oil with the "mileage" additives that make it too slippery. Before you tear the engine apart, you might try flushing the engine oil with Sea Foam and replace to see if it slips less.
Another thing that can cause hard shifting is if the oil is too thick. Some sneaky people will put heavy oil into an engine on something they are selling to quiet it down.:laugh:
- gaillarry
When I checked the clutch cable I turned the adjuster on the sprocket cover counter clockwise until tight then 1/2 turn clockwise and tightened the locknut.
The owner showed me the oil he used, normal 10W-40 motorcycle oil. Shifting up is fine,but shifting down is noisey and very difficult.
1977 KZ1000
1985 Gpz750
- Tyler
- Thank you received: 92
"74 Yamaha DT 400 Enduro
