- Thank you received: 2
Oil cooler. To cover or not to cover...that is the question!
- davenkids2001
When I bought my bike 3 years ago it was 99% stock except for a luggage rack and an oil cooler. The oil cooler looks like the standard Lockhart type fin and tube, mounted on frame. Unbeknownst to me at the time, the bike also came with a cover that fit over the oil cooler. It looks either like a original cover or was a very well crafted, home-made assessory.
Does anyone here ever cover their oil cooler in cooler weather? Is it ever necessary to cover an oil cooler at all? Since I bought this bike I usually ride with the oil cooler uncovered, but on certain times, like short runs or during weather under 50*F (10*C) I will cover the cooler. Is this necessary?
I welcome all opinions...
Dave and Janet
Great Lake State
1979 650SR
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- RonKZ650
- Thank you received: 240
- letthegoodtimesroll
- Thank you received: 1
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
- bountyhunter
- Thank you received: 337
I wondered the same thing as engines are supposed to run at "operating temperature". Running it uncovered may not allow the engine to get to the right temp as it may keep the engine temp too low.
I thought the good aftermarket coolers had thermostats that prevented oil from flowing in the outside loop until the engine got up to temp? The ones I saw did.
Lockhart Oil Cooler Thermostat
Instals between the oil cooler and the oil pump, this control valve accurately maintains the oil temperature. Benefits includes faster warm ups, improved gas mileage and longer engine life. Available in black or chrome
Lockhart Oil Cooler
The 600 series is the first true automatic thermostatic control oil cooler system for motorcycles. The thermostat or bypass valve is rigidly sealed inside the brazed housing, eliminating the use of separate units and mounting difficulties. The bypass will fully open at 180 deg preventing over cooling or oil pressure resistance in cooler weather.
- davenkids2001
I was just curious if anyone else has this set-up and what are the opinions of ever using a cover over it and under what conditions.
Thanks
Dave and Janet
Great Lake State
1979 650SR
- Z1109R Fin
Z1000R ´83...Slightly modified...
- Jeff.Saunders
I do know people who have to cover their oil coolers when the temperature drops significantly.
It probably will depend a lot on how far you ride abd what temperature ranges you ride in.
Even if your oil cooler has a thermostatic bypass, the oil will typically still run through 1 rail in the cooler - so you still get far more oil cooling than with just a conventional air cooled engine.
www.z1enterprises.com
Z1 Ent on Facebook,
- Murphyau
- Thank you received: 4
