Help Stuck Barrels
  • stever
  • stever's Avatar Topic Author
Help Stuck Barrels
06 Apr 2008 11:46
#204593
Got a 1075 wisco to fit. started stripping it down, I have got the head off but can not get the barrels off, have now broken a fin so am well pi##ed off.
Any suggestions gratefully received?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Help Stuck Barrels
06 Apr 2008 12:33
#204606
should be a pry point olong base of cylinder,dont pry on fins:(
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
06 Apr 2008 14:30
#204625
Stever, like PLUMMEN said, there is a pry point on both side of the barrels, along the base. Use a large screwdriver as a prybar, sometimes it takes a fair amount of leverage to get the barrels to move a bit as you or the PO might have used gasket sealer...the old gasket also tends to act as an adhesive.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • nads.com
  • nads.com's Avatar
06 Apr 2008 15:45
#204642
put pressure on it and whack it with a rubber mallet
  • Kiwiz
  • Kiwiz's Avatar
13 Apr 2008 22:54
#206285
Try diesel down the stud holes and apply some upward tension to the barrels. Wrap some rope or nylon strapping around the barrels & if engine is still in the frame, tie over frame spine (top) and leave the rope in tension, so its pulling the barrels firmly up, away from the cases
If the engines out of frame, rig it up so the engine weight is just supported by the barrels - similar arrangement as above to keep in tension
Then use a broad bladed screw driver in the pry slots
  • bountyhunter
  • bountyhunter's Avatar
14 Apr 2008 09:18
#206361
I broike some very large (and expensive) screwdrivers trying to pry the cylinder up on my 750. Here is what worked:
I got an old small tire iron and machined the end to just fit into the pry gap on the sides. Eventually, I got it to move.
On mine, the cylinder base gasket was a thick rubber asphalt type material with glue on both side (from the factory). The glue was so strong the gasket stayed bonded to both surfaces. I had to tear the gasket apart to get it off. Worst part of the whole rebuild, thought I was never going to get it to move.
And I did chip a small piece out of the fins prying on it, that probably comes with the territory.
