Roller cam chain capable 750 head/cylinder update
  • steell
  • steell's Avatar Topic Author
05 Apr 2008 20:08 - 05 Apr 2008 20:09
#204513
Just to add to the continuing accretion of knowledge regarding what years of 750 blocks and heads will work with the roller cam chain of the 650's.
I pulled the top end off a 81 KZ750H motor today (at least according to Zedder it's a 81 750H serial number, and it's not black), and discovered that it too has the provisions for the roller chain guides in the block, and the holes for the top roller chain sprocket (tapped and ready to use) on the head. Based on the condition of the cylinders/pistons, and of the cam chain guides, I'm confident that the cylinders and head have not been replaced in the past.
I have personally verified the following.
1980 KZ750E will work.
1981 KZ750H will work.
1983-85 GPz750 will not work.
Cab anyone else add personal verified info to the above?
Maybe someone will take this info and create an article for the Filebase or something :)
Last edit: 05 Apr 2008 20:09 by steell.
  • kxhonda
  • kxhonda's Avatar
Re: Roller cam chain capable 750 head/cylinder update
05 Apr 2008 21:15
#204521
So far I have bought 2 heads off of ebay that the seller said were 81's and they both have had the right provisions.
1977 Kz650B1 #576th made.
Warsaw, In
