Gasket Coatings?
- DACarpy
04 Apr 2008 09:05 #204196
by DACarpy
Gasket Coatings? was created by DACarpy
Working on a 83 KZ750 Spectre, Replacing base gasket, head gasket, and cam cover gasket. Among other things...but for now...
What are your thoughts on aersol gasket coatings? The general consensus seems to be not to use them on these composite material type gaskets.
But I thought I'd check with you folks to get your take on what if anything you use.
Thanks!
Dan
Thanks!
Dan
- bountyhunter
- Thank you received: 337
04 Apr 2008 09:51 - 04 Apr 2008 09:52 #204205
by bountyhunter
Replied by bountyhunter on topic Gasket Coatings?
DACarpy wrote:
cylinder base gasket: the one on my 750 came from the factory with a VERY strong adhesive (it was a bugger to get off). I used ultra hi-teml RTV to seal the new one on. May not be absolutely required.
head gasket: if both surfaces are polished dead smooth, you should not need sealer (if it's a good quality gasket). I did use a bit of the copper head gasket spray on mine last time because it tends to seep oil a bit at the front, most don't need it.
Cam cover: I use a little RTV across the tops of the rubber "half moon" plugs because they always like to leak there. I don't think fully sealing the whole cover is necessary, but it doesn't hurt anything.
Thanks!
Dan
Last edit: 04 Apr 2008 09:52 by bountyhunter.
