I want to cap off tachometer hole - what thread size?
- elcid
03 Apr 2008 17:39
I am not using a tach & want to cap off where the cable connects to the engine. Can I just screw an acorn nut over it to cover it up? If so, what thread size? Thanks!
- reborn650
Re: I want to cap off tachometer hole - what thread size?
03 Apr 2008 18:55 - 03 Apr 2008 18:57
I did this little surgery on my 650 head when I put in the 750 Gpz cams that didn't have the tach drive. Had no luck matching the pitch on the threads as they seem like a pretty coarse, oddball size.
My first attempt was with a cast galvanised pipe cap that I picked up from a plumbing wholesale supplier. I coated the threads with Seal-All, which is an oil and gas-proof, automotive adhesive.
This worked not too bad but I didn't like the look of the cap which kinda seemed out of place. I decided to simply re-install the tach cable (without the pinion gear or inside cable) and put a little dab of two-part epoxy glue on the threads. This allowed me to keep the stock look with the tach cable connecting from the head to the non -operational tach. No problems with any oil leaks.
I like the stock look and for anyone who knows these old engines won't suspect that I have any interior upgrades. Just trying to keep the sleeper theme going:-)
1977 Kz650 Custom. 810 big-bore, WG Mikuni 29 Smoothbores, Gpz750 cams, Gpz 750 intake valves, ported, polished and milled 650 head, Velocity stacks, Lower gearing, MAC Pipe, 130 rear tire, APE cam chain adjuster and lots of other goodies. Stock looking Moondust Silver paint job. Miss January on the 2007 Kzrider calendar.
-1998 Jeep TJ Wrangler 4.0...
Last edit: 03 Apr 2008 18:57 by reborn650.
- elcid
03 Apr 2008 20:47
I don't want to use the cable at all as I don't have any gauges. Anyone know the thread size? Or anyone come up with a way to seal it - well?
- donthekawguy
03 Apr 2008 23:06
You should put your bike in your signature line so people know which bike your talking about. Anyway, I picked up one of those plugs from Jeff that fit in the hole. It is for a 1000 so you might want to start at Z1 to see if someone makes a plug for your bike.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- elcid
03 Apr 2008 23:57
well my bike is not stock at all so you would not even recognize it!
It just plugs in there & stays??
- FloridaBiker
04 Apr 2008 09:17
I have done this twice.
Just take your old tach cable and cut off the end.
Slide off the 'nut' that crews onto the head.
Fill it with silicone and install.
Makes a nice permanent fix.
- elcid
04 Apr 2008 11:31
That would work IF I had a tach cable. I don't. I don't want to pay for a new one just to cut it up. Does anyone know the thread size?
- mark1122
- Keep twisting it
07 Apr 2008 11:06
try a local bike wrecker.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
