KZ650 Engine Swap
- seanof30306
KZ650 Engine Swap
02 Apr 2008 12:54
I have an '80 KZ650 with no engine, and access to a free running KZ550 engine.
Understanding anything will fit with enough cutting/welding, etc., will The KZ550 engine easily fit on the KZ650 frame? How much fabrication is required, or will it bolt directly over?
The 550 engine comes with a Mac 4-1, will that fit?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- Ituen
- Rider
Re: KZ650 Engine Swap
02 Apr 2008 13:12
Have the 550 motor taken out to 615cc before you bolt it in.
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- seanof30306
02 Apr 2008 13:22
So, you're saying it will bolt in?
I'm looking at doing this to make a few bucks, so I'd want to do it as inexpensively as possible. I'd prefer to leave the displacement alone.
Besides, leaving it at 550 means I can sell it as a gas saver.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- RonKZ650
02 Apr 2008 13:42
I think the 550 will bolt in, but the part I'm worried about is the exhaust spacing. Being narrower on the 550 I'm wondering if the pipes will not fit between the front frame tubes.
- seanof30306
02 Apr 2008 20:17 - 02 Apr 2008 20:20
Yeah, I looked at it, and that would definitely be a concern. I wish I had a KZ550 fram to take some comparison measurements on. I guess the only way to be sure would be to mock it up.
Hopefully, someone's done/tried it, and can share their experience.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
Last edit: 02 Apr 2008 20:20 by seanof30306.
- mjg15
02 Apr 2008 21:51
I think that the 550 engine is a bit smaller , you should have plenty of room . As mentioned , the exhaust spacing could be an issue .
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- seanof30306
02 Apr 2008 22:10
The question is, whether it would actually bolt up to the existing mounting points.
And, the exhaust spacing would definitely be a deal-breaker.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- mjg15
02 Apr 2008 22:22
Don't know if it is a "bolt in" . I would be surprised if it was . The cases are different and the 550 is probably more than an inch shorter front to back . I have a bare 550 frame (that I'm putting a Suzuki Katana750 motor in) if you want some comparison measurments I can check some stuff .
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- mariozappa
03 Apr 2008 05:47
They quite a bit different in size, my buddy has a 550 LTD.
I don't have any measurements though, hopefully mjg15 can help you out.
1977 KZ650C1
and the KZ650/KZ750 Conversion
