80 kz550C trans problems- help!
- Quirkson
other bike info-
- around 30k miles
- oil/filter change with 20w-50 motorcycle oil less than 500 miles ago
- carbs cleaned less than 100 miles ago
1980 KZ550c
- steell
It's been a year or two (probably 2) since I worked on a 550 trans, but I think 2nd and 5th uses the same shift fork (there are three shift forks).
Loudhvx is the 550 expert, not me
- Quirkson
1980 KZ550c
- steell
any way to tell if that is indeed the problem without cracking the case open?
There's other things you can check first, like the shifter mechanism behind the engine sidecover.
I haven't worked on any 550's, I just put the 550 six speed trans in a gPz750.
- GPz550D1
- Thank you received: 22
Robert
1981 KZ550-D1
- loudhvx
- Thank you received: 1616
I didn't experience 5th/6th problems though.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- GPz550D1
I had the same problem in 1st/2nd and neutral finding after the motor was warm. The fix was new Kawasaki friction disks (although I replaced the steel plates too). I went through aftermarket friction disks and they slipped way too much, even with new stock springs. I called several speed shops around here and they all said practically the same thing: "throw away the brand new aftermarket disks and put in factory disks". The few extra dollars for the factory disks was worth every penny.
Thanks Lou, I will be installing new Kawasaki frictions and steels in the near future, along with OEM springs.
Robert
1981 KZ550-D1
- loudhvx
1981 KZ550 D1 gpz.
Other links.
