- Thank you received: 109
calling all racers
- mark1122
- Keep twisting it
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
- Thank you received: 104
- Dirtybiker
Scott
- PLUMMEN
- 77KZ650
- Thank you received: 7
07 MDP Rookie of the Year
- BSKZ650
- Thank you received: 14
get them close, but I think you will find them from the factory to be fine, dress any sharpe edges, check the ring gap, and make sure the bore is round and has a good cross hatch pattern.
77 ltd1000, current rider
76 kz900, just waiting
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 77KZ650
thanks guys. my 1135cc wiesco's were out 4.5 grams . i had a vibration below 3000rpm. the mtc 1327cc's were out 1 gram. i took a page out of my last builders book. he had added a 2nd oil hole in the piston for the wrist pins. so i drilled a 2nd hole in each pistons wrist pin boss and through to the oposite side of the pin whole till i got the pistons all the same weight. less than 1 10th gram dif.
niceB)
ill be trying to get the JE's going into my 12r that close...extending the revlimiter is going to be tough on it, so i want it as smooth/balanced as possible:woohoo:
