Rebuilding kz650... where to buy rings?
- jordan172005
- Bluemeanie
- Thank you received: 14
Example... Wiesco has one..
KZ650 1976-83
Kit includes: (4) Pistons, Ring Sets, Piston Pins, Retainer Clips, and (1) CFM20 Head Gasket
700cc
Sugg Retail $580
Dynoman $429.95
2.520" or 64.00mm
2mm oversize
Stroke - 54.38 K700 10.25:1 Cylinder boring only
Piston: 4037M06400 Rings: 2520XC Piston Pins: S522
Retainer Clips: CW15 CFM20 Head Gasket: W2486
- Thank you received: 2829
- Bluemeanie
- bountyhunter
- Thank you received: 337
Cool, 650ed! I thought we had discussed that here and they were no longer available? Everyone gets all excited when some show up on ebay. I'll have to check out Ron...
If you have cylinder wear (and you are not boring the engine) you might want to get the +0.25mm over ring set and shave the ends of the rings until you get the correct end gap in your cylinder. It will compensate to some degree for the cylinder wear. Not as good as boring one over and replacing the pistons and rings, but a lot cheaper.
- bountyhunter
According to Kawasaki.com the standard size is still available (part #13008-059). Ron Ayers lists them for $46.50 per set. I bought 4 sets on Bay about 9 months ago for $9 per set in case I ever need them, so they do show up on eBay sometimes. Ed
babbittsonline.com used to have the best prices on OEM kawi parts, you might want to price stock rings there.
