Valve cover coming off
- kneedragger80
While I have the cover off, is there anything I should be looking for or check while I have it open? Any adjustments or anything else I should address while I have the chance?
80 KZ750E
84 GPZ1100
NY US
. . . I used to do a little but a little wouldn t do it so a little got more and more . . .
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- ronjones
- Thank you received: 4
- PLUMMEN
- Thank you received: 104
- steell
- bountyhunter
- Thank you received: 337
Always take the time to check valve shim clearances at opportunities like this...you should also consider replacing the valve cover gasket at these opportunities and be prepared to swap shims, if need be.
Considering the price of cover gaskets, you may want to buy some gasket material at pep Boys and use the old one for a pattern. The dealer wanted $80 for mine.
- bountyhunter
Those things do like to leak. They aren't cheap to replace, I think mine were about $60 for a set. If they are not too bad, you can seal them by prying them out and cleaning them up and then setting them back in with good RTV sealant. I used the ultra high temp black stuff.You might need to replace those end cap seals, along w/the gasket.
- grandadbob
This is a really top tip. Remember to fit alloy washer to cam tensioner cap on assembly. I forgot and sheared tensioner body at base of thread.
'83 KZ550 C4 LTD
'06 VFR800 Vtec
- kneedragger80
80 KZ750E
84 GPZ1100
NY US
