OK to use wheel block to stop engine turning?
  • apeman
  • apeman's Avatar Topic Author
26 Mar 2008 10:26
#202277
There are various repair activities that require keeping the engine from turning while loosening a high torque bolt or nut. Examples: removing the clutch hub nut, and removing the front sprocket nut. I do not have an air impact wrench, so I need to use a breaker bar, sometimes with an extender for extra leverage. Many people on this site have suggested facing the bike front wheel up against a wall to create resistance to keep the engine from turning. Sometimes I work in my yard or driveway (California weather is great), and a wall is just not handy.
Is there any reason I should not use the following substitute technique?: Place a large hardwood dowel (i.e., a closet rod) through the bike frame and spokes of the rear mag wheel, thus keeping the wheel and engine from turning when I torque on the breaker bar to remove the ofending nut/bolt. I know this should not be done with wire spokes (duh), but my bikes all have mags. I am risking damage to my wheel?
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
  • baldy110
  • baldy110's Avatar
Re: OK to use wheel block to stop engine turning?
26 Mar 2008 11:04
#202284
I don't see aproblem with that as long as your wheels are mags. I've used that technique for years before I got impact tools.
  • Qdude
  • Qdude's Avatar
  • It is all good.
26 Mar 2008 11:17
#202289
Especially if you use wood to block the wheel, I would imagine. It would distribute the pressure where metal might cause a little fracture. Seems ok to me, using common sense of course.
77 KZ 650 C1.
77 KZ 650 C1.
  • ronjones
  • ronjones's Avatar
26 Mar 2008 13:01 - 26 Mar 2008 13:03
#202309
To be on the save side you might want to 1st try a piece of wood that will break before you put enough pressure to crack the mag. Like a 2X2, rather than a 2X4.
Last edit: 26 Mar 2008 13:03 by ronjones.
  • OnkelB
  • OnkelB's Avatar
26 Mar 2008 14:38 - 26 Mar 2008 14:39
#202330
I tried the up against the wall approach (with the bike that is) to loosen the clutch hub nut on my 650, but being fairly light (less than 180 lbs) I couldn´t prevent the back wheel from spinning by sitting on the bike - ended up sticking a broom handle in the rear wheel, worked like a charm.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 26 Mar 2008 14:39 by OnkelB.
  • Rickman
  • Rickman's Avatar
26 Mar 2008 21:20
#202408
I've heard about putting a penny in the gears where the clutch basket meshes, would that help you?
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
  • davenkids2001
  • davenkids2001's Avatar
27 Mar 2008 06:42
#202463
I dunno if this helps in all situations but last year when I changed my drive sprocket I ran into a similar issue. My solution was to have my honey bunny step on the rear brake lever to jam the wheel while I turned off and on the sprocket nut, but this only works IF you still have your chain on both sprockets. It worked great.
Dave and Janet
Great Lake State
1979 650SR
  • PLUMMEN
  • PLUMMEN's Avatar
28 Mar 2008 20:35
#202818
lock up the brakes as previously mentioned.B)
  • OKC_Kent
  • OKC_Kent's Avatar
30 Mar 2008 08:08
#203064
Above method is what I had to do, with one big teenager on a pipe to crack the sprocket nut off.
Cashion, OK
78 KZ650 B2 85,000+ miles
