cam timing tools/numbers
  • jimmybon
  • jimmybon's Avatar Topic Author
Re: cam timing tools/numbers
27 Mar 2008 16:09 - 30 Mar 2008 19:10
#202558
Paling1 wrote:
jimmybon wrote:
(ZR750 head and GPZ750R1 cams)
Did you use a ZR-7 head? Or did you use a Zephyr 750 head?
I have a ZR-7 head in my shed, and I want to put it on my KZ700. I also have a set op GPZ cams, so I would like to put them in the ZR-7 head, but I've read that the ZR-7 cams are a bit different from the older KZ or GPZ cams... (not the lobes, but the camshaft itself).
Here in Oz we have a ZR750 zephyr 91 - whatever and then the ZR750 ZR7 basically the same engine and indead the same as a GPZ750 and the KZ750
If you look closely at the ZR750/ZR7 head you will see at the front the embossed area for a mechanical/cable driven tacho. I'm not sure exactly what year model was the last for kawasaki to use this but appox 1980
If you can fit a KZ750 head onto a KZ700 ( not released in OZ ) then a ZR750 would fit also
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
Last edit: 30 Mar 2008 19:10 by jimmybon.
  • cafekz750
  • cafekz750's Avatar
18 Jun 2008 10:47
#220712
This is a really cool post and thanks for all the info and set up. I am thinking about degreeing my cams on a couple of my bikes this winter. How do you like the 104/106? Have you tried other settings? Curious since I have a KZ750.
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
  • mtkawboy
  • mtkawboy's Avatar
18 Jun 2008 13:00
#220737
members.tripod.com/gpz_rider/technical/FAQ2000.htm good cam timing article on this site
  • jimmybon
18 Jun 2008 15:57
#220752
Thanks Cafe, 104/106 are good numbers from what i'v found. When i first checked the cam timing after 30,000km of mono's, track days and simply froggin the hell out of her, I found the timing at 108/102. These numbers could have been because of the marry of zr750 head and barrel on a gpz bottom end, or, were and tear, I'm not sure, but definatly runs more crisp now. Short lived though, i'm now changing the cams to gpz zx and have to start all over again
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
  • jimmybon
18 Jun 2008 16:16
#220754
cheers
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
