Okay, now I've gone and done it--Got some GPZ cams. Now what?
  • Skyman
  • Skyman's Avatar Topic Author
20 Mar 2008 23:10
#201315
So I was snooping around on EBay this afternoon, and I happened to find an auction for a set of '84 GPZ 1100 cams that was just about to end, and the price was still low. I thought, hmmm, those would really go nice on my M2-1135. B)
So I sniped it, and picked them up for $41. So I've got those on their way to me now.
I know that this brings up at least one problem: the tach. My bike uses a mechanical tach, and these cams have no tach gear. So my options are to either do without a functional tach, or figure out a conversion to an electronic tach. Any suggestions?
Next question--and I know what you guys are going to say, but it's not the answer I want. :silly: Should I replace the valve springs too? Well, duh--I probably should. But would it be that big of a deal if I just kept my stock springs for a while?
Any other issues I need to be aware of?
Thanks, guys.
West Linn, OR
  • steell
  • steell's Avatar
Re: Okay, now I've gone and done it--Got some GPZ cams. Now what?
20 Mar 2008 23:36
#201316
KZ1000K (LTD) and KZ1000J both have an electronic tach, so the simple answer is to get a set of gauges off one of those.
If your stock valve springs are still within specs, then I don't see any reason to change them. The GPz1100 cams are not a great deal different than the stock cams, I think somewhere between .365 and .385 lift.
  • FloridaBiker
  • FloridaBiker's Avatar
21 Mar 2008 04:07
#201325
The KZ1100 shaft also has an electronic tach.
