exhaust question
- kz750ohio
exhaust question
19 Mar 2008 23:44
I am thinking about coating the inside of my exhaust to help keep the blueing effect from happening. The question I have is how hot does the pipes get? The reason I ask is I was considering buying the brake caliber high temp paint (500 degree) in a quart can. I thought if I clean the inside of the pipes with a wire brush pretty good and then pour some of the paint down in there and work it around I could get a pretty good coat. Someone give me some input on this.
Also I have almost finished the bike. I will be posting pictures soon. My dad says its a night and day difference. I say its over 400 man hours difference.
cheers
cheers
1982 kawasaki kz750 with mikuni carbs bs34, stock everything else.
- bountyhunter
Re: exhaust question
20 Mar 2008 09:22
The header paint I used to spray the OUTSIDE of the headers on mine was rated at about 1000F as I recall. I don't think 500F is good enough, especially for the inside of the pipe which is getting the full blast of hot exhaust.
I honestly don't think any paint or coating is going to live on the inside of the pipe, just my opinion. I also don't think it will stop the bluing. The pipes that don't blue have a double wall construction with an air gap which keeps the outer pipe significantly cooler and prevents the bluing.
- bountyhunter
20 Mar 2008 09:23
kz750ohio wrote:
Wow, that is true dedication. Must be looking good.
cheers
- The Milkman
20 Mar 2008 09:32
Rustoleum makes a 1200 degree barbeque grill spray paint, that should do it.
- agawam
21 Mar 2008 20:30
I like the blue on pipes gives it that "I ran the hell out of it" look
- KZQ
- Administrator
21 Mar 2008 20:56
I saw a modern Triumph Bonneville with just 3K on the clock This past Monday, both pipes were blued nearly to the foot pegs. Sortta had that, I wish the Govm't'd leave me alone type of look.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
