kz650 noisy top end...
- Kingcobra
18 Mar 2008 16:48 #200825
by Kingcobra
kz650 noisy top end... was created by Kingcobra
not knocking or anything like that.... just seems I can hear the mechanicals a little too much... any idea why? kinda like a sewing machine sound... is it normal?
- The Milkman
- Thank you received: 194
18 Mar 2008 17:04 #200829
by The Milkman
Replied by The Milkman on topic kz650 noisy top end...
It should be quiet, it sounds like your valves need adjusting. Check the guide spocket between the cams for play or roughness while spinning, also.
- flht1997
- Thank you received: 2
18 Mar 2008 17:23 #200834
by flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
Replied by flht1997 on topic kz650 noisy top end...
noisy valves are happy valves but seriously i would start with a cam chain adjustment and check the valve clearance.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
- Kingcobra
18 Mar 2008 19:26 #200852
by Kingcobra
Replied by Kingcobra on topic kz650 noisy top end...
ok thanks guys... how do you adjust the cam chain? 78 kz650b
- Thank you received: 2098
18 Mar 2008 20:06 - 18 Mar 2008 20:10 #200859
by Patton
Replied by Patton on topic kz650 noisy top end...
And might add to previous suggestions that properly synched carbs usually contribute to a smoother and quieter idle.
P.S. And would also assure ignition timing is set to specs.
And that valve clearances are also within proper specs.
Last edit: 18 Mar 2008 20:10 by Patton.
