exhaust collar question
- riverroad
- 1980 1000LTD B4
17 Mar 2008 08:47
Can someone tell me if the header pipes on KZ1000's are the same sizes as on KZ650 or 750's?
Having a hard time finding split collars for my header. I have this annoying little exhaust leak on #4, and I think it's because I didn't pay any attention to which collars went where last time I had the header off.
They're six bucks apiece at the stealership.
- mariozappa
Re: exhaust collar question
17 Mar 2008 09:11I didn't pay any attention to which collars went where last time I had the header off.
I am under the impression ALL the collars are the same size for a set of headers.
I had a different header that took shorter collars than stock, but they were all the same size.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- riverroad
- 1980 1000LTD B4
17 Mar 2008 09:50
That's what I thought as I pulled the header off and the split collars fell off Mario. But when I started looking at them, some were a little shorter than others.
I was just wondering if the exhaust port sizes were similar between 650's and 1000's. I kinda doubt it, but I had to ask.
- RonKZ650
17 Mar 2008 10:18
Exhause pipes are larger diameter on the KZ1000 so I think the collars would be different
- riverroad
- 1980 1000LTD B4
17 Mar 2008 10:31
Thanks Ron, I figured that, but I wasn't quite sure.
Seems like I see more of them things for 650's than I do for 1000's on Ebay.
- rstnick
17 Mar 2008 18:43
I was told recently (by Gringo I believe) that 750 split collars are shorter than 650's.
Not sure if this helps you.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- roystaylor
17 Mar 2008 21:08
A 650 is smaller than a 1000, because 1000 is more than 650.
With gas at 3.35 a gallon, what's the small cost of the correct collars going to dent your budget???
- riverroad
- 1980 1000LTD B4
18 Mar 2008 05:12
Gee, you're smart Roy. I never woulda thought 1000 would be bigger than 650. But as I live in a manufacturing world, I was thinking maybe, just maybe, Kawasaki might've kept their costs down by a little known phenomena called "uniformity of parts" between models. But as I've found out now (which is why I asked), that isn't the case in this instance.
And at 6 bucks per stamping, that's 48 bucks for eight little pieces of stamped sheet metal, which is ridiculous. Considering what they are, they should be more like 50 cents apiece. Compare that with your average .99 cent spark plug, which is a lot harder to manufacture than a curved piece of sheetmetal, it doesn't take a rocket scientist to figure out that I'm getting shafted by the dealer.
I might fork out the 48 bucks, or I might go ahead and make a stamp and die so I can make my own.
- Locozuna
18 Mar 2008 06:14
Damn! First it was vacuum cleaners and now it's economics! Anybody knit their own fishnet stockings?:woohoo:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- fastestz1
18 Mar 2008 08:03
Locozuna wrote:
lmfao
lmfao
- The Gringo
- ¡Usted no necesita otra motocicleta!
18 Mar 2008 08:51
I have to agree with riverroad on this one, 6 bucks each seems high. When I installed my ZR7 exhaust I needed to get the shorter 750 type inserts. I was originally going to cut the 650's down but as luck would have it someone here needed a set for a 650 so I just sold him mine and ordered new ones from Kawasaki. IIRC they only cost like $2.97 each. At that price it was worth it to me to know I would still have all my digits when I was done.:laugh:
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- kzwolfsr
18 Mar 2008 20:42
T he ones z1 are selling just look like pieces of cut up pipe
Original man of the Caribbean
