I got drunk one night and stupidly started playing around with the bike. For some reason, not sure still, I wanted to see something around the intakes on the old Kerker I have on her. Anyways, I loosened one of the bolts holding #1 exhaust to the engine. Neighbor girl calls me over and I forget about it. Coupla days later I was running an errand and I was hearing this perfectly timed hiss comming from in between my legs. WTF? Luckily, one of my good friends is an old racer from the 70's early 80's and can be plied with a few beers. He figures it out pretty quick with a stethascope rigged up for just such matters. He was also my mechanic back then thank god, man's a genious on bikes. We pulled the pipes, and sure enough, #1 had a crack on the the rim of the intake on the Kerker. Had a semi-circular piece of the pipe break off, most likely to bad installation, or heat related because of my drunken loosening of the bolt holding it there (idiot). We JB'd it. At the time I was pretty damn sure- and so was he- that this wasn't going to work. I can weld but I didn't have a way to do it and at that time, no ca$h really. Damn if it didn't work perfectly. Still riding w/o a problem there. After that, my other good buddy wiped out pretty good one night and cracked his case (Honda POS) I told him you can JB it because welding it wasn't going to work (metals issue there). It holds the oil pressure just fine and cosmetically it looks good. Boom! He's still riding it, 3 years later. I am a believer if you prep it right. JB weld is good stuff.
77 KZ650 'C'
Bachelors know more about women than married men; if they didn't they'd be married too.
