JB Weld Experiences
  • Qdude
  • Qdude's Avatar Topic Author
  • It is all good.
JB Weld Experiences
16 Mar 2008 10:48
#200349
I gouged out about three square inches of my block just under the ignition cover (right side) when I crashed recently.
I used JB Weld, which is a heat tolerant metal infused epoxy putty for those who didn't know (myself included).
I built up a dam with duct tape of all things, to which I applied the putty. I put it in thickly so that I could file it back to the original shape.
Took fifteen hours to cure, but it filed wonderfully! In fact, once it is painted, it will be hard to see that there was ever damage in the first place.
Has anyone ever used a similar method to repair block damage?
How will it deal with the heat and vibration? The package said 500 degrees.
77 KZ 650 C1.
77 KZ 650 C1.
  • BohicaBob
  • BohicaBob's Avatar
Re: JB Weld Experiences
16 Mar 2008 12:29 - 16 Mar 2008 12:30
#200385
I repair broken fins and what not on my Zs using JB Weld too. How long might JB Weld repairs hold up?
When I crashed my '73 Z1-900 in 1977, I repaired the three broken fins on the right side of the cylinder head. All three are still on just fine.:)
Last edit: 16 Mar 2008 12:30 by BohicaBob.
  • Skyman
  • Skyman's Avatar
16 Mar 2008 13:29
#200399
I too have repaired fins with JB Putty. Works great.
West Linn, OR
  • The Milkman
  • The Milkman's Avatar
16 Mar 2008 14:57
#200415
I repaired a broken ear on my intake side of the head with the stuff it works great.
For smaller projects I bake the piece in the oven at 250 degrees, makes the bond even better and gives it a nice smooth glazed finish.
  • OldSchoolHr
  • OldSchoolHr's Avatar
  • Kawasaki z900a4 1976 Croatia, Europe
16 Mar 2008 15:11
#200419
Is there any pics of that JB weld I have never heard about
that. I have also one broken fin on head of my z900 which
I want to repair!
Has someone got pics of fin repaired with Jb weld?
  • nads.com
  • nads.com's Avatar
16 Mar 2008 17:32
#200465
Wish they had a second formula that wasn't so brittle. The uses would be many.... CRACK!
  • kzwolfsr
  • kzwolfsr's Avatar
16 Mar 2008 18:24
#200469
I just repaired a broken line on my jeep with it and now I am saying my prayers
Original man of the Caribbean
  • OKC_Kent
  • OKC_Kent's Avatar
16 Mar 2008 19:15 - 16 Mar 2008 19:16
#200479
Qdude,
I have repaired my 750 with JB Weld. It had the same damage you speak of, the ignition case was broke. I riveted a piece of sheetmetal perforated screen and layed up a few coats of JB on it. It is rock hard. I have yet to give it a try as the bike is in the project stage.
If you want to hear and read something almost unbelievable check out this guys website. Sign up for it and you get access to his hi-velocity intake porting pages. What does he use in his intake ports? JB Weld.
www.mototuneusa.com
Cashion, OK
78 KZ650 B2 85,000+ miles
Last edit: 16 Mar 2008 19:16 by OKC_Kent. Reason: link bad
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
16 Mar 2008 20:22
#200490
When you're laying up the JB Weld it can be wet shaped just like modeling clay. The trick is to let it just start to set up and just rub/rinse the surface to the shape you want. It'll save you hours of sanding filing time and will have no effect on the eventual strength of the repair.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • 77KZ650
  • 77KZ650's Avatar
16 Mar 2008 22:52
#200504
my 12r cases were fixed with jb weld right under the stator cover. the PO crashed/ fixed the bike. works greatB)
07 MDP Rookie of the Year
  • Skyman
  • Skyman's Avatar
16 Mar 2008 22:59
#200505
I want to repair!
Toni,
Here is the J-B Weld website: jbweld.net/products/index.php
What I used to repair the broken fins was similar to the "J-B Stik" product, but I didn't actually use J-B brand. What I used was a high-temperature epoxy putty shown here:
West Linn, OR
  • Skyman
  • Skyman's Avatar
16 Mar 2008 23:01 - 16 Mar 2008 23:05
#200507
Here is the "before" picture of my cylinder block:
West Linn, OR
Last edit: 16 Mar 2008 23:05 by Skyman.
