- Thank you received: 2
Cam install / timing
- 2bskor
Also when resetting the tensioner before you put in the engine should the short bolt go back in, maybe the tensioner is extending too far ??
I came a very long way to get to this point and I'm determined to see it till the end !!!!!!!!
Any help would be great
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
- OnkelB
- Thank you received: 80
Anyway, I take it the T mark moves clockwise - if the crank rotates when you release the tensioner plunger and the cams don´t, yeah, I´d say you have too much slack in front.(I´m surprised that the tensioner can rotate the crank, but I´d be even more surprised if it could rotate the cams too.)
I´d redo the cam install making sure the chain is taut at the front when you install the exhaust cam - also check that it is on the front idler gear properly, still assuming we´re talking about a KZ 1000.
77 KZ 650 B1, 82 GPz 1100 B2.
- 2bskor
I put the tensioner in and voila the crank is on the T the cams are lined up, well the front one is not perfect but if you move it one tooth it is too far and where it is is just a tad higher on the front cam back line mark that I would like but I have reinstalled the cams,chains three times this is the closest I have gotten. I rotated the crank a few revolutions and everything seemed fine. I am afaraid as hell to start it:(
All this to stop a frigin oil leak.
And ya it is my kz1000st, man I don't like this new site!!
- 2bskor
- 2bskor
- 2bskor
- Bluemeanie
- Thank you received: 14
- OnkelB
I am afraid as hell to start it:(
/quote]
Yeah, I know that feeling. :S Looks good to me, and if you could rotate the engine without anything catching up you´re probably good to go - the most important thing is the correct amount of teeth between cams. Have to admit that I don´t have that much experience with the 1000s though, so you might want to wait starting her up until someone more qualified than I has chimed in.
Btw, we could never post multiple pics here, the only way to do that is to have them on another site and linking to them.
- OnkelB
On the multiple pic thing, something new I just found that clicking on your first pic to full size, it said "next" and I saw all three pics from the one! Cool!
That´s neat, I didn´t know.
- Wizzard
1977 KZ 1000
4-1 Headder
K&N filter
530 Chain & Sprokets
Rear Air Shocks
- 2bskor
You say it only fires on two cylinders if so which ones?
- Wizzard
1977 KZ 1000
4-1 Headder
K&N filter
Rear Air Shocks
