Points v/s Dyna Electronic Conversion
  • mikemac01
  • mikemac01's Avatar Topic Author
12 Mar 2008 19:12
#199825
I have a 77 kz750 and am doing a major tune up. Is it worth the 125 bucks for the electronic upgrade or stick with the old points. If I go with the conversion what will I gain. Thanks
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Points v/s Dyna Electronic Conversion
12 Mar 2008 19:24
#199827
Hi Mike,
Go with the Dyna. I've always had good performance out of my KZ900, up to about 7500RPM. Above there and it's all sputter and miss. If I fiddle with the points I can get to really run but the points seem to fall off fairly quickly.
kzcsi
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • N0NB
  • N0NB's Avatar
  • Blue handles better
12 Mar 2008 19:25
#199828
I've replaced the points with Dyna S electronic ignitions on my two 650's and they seem to be easier starting and idle smoother than with the points. Once set the electronic pickup will be maintenance free unless it ever fails.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
12 Mar 2008 19:44
#199831
Both have pros and cons. I've kept the points ignition on my '77 KZ650C1 and it runs very well. However, they do begin to pit at around 4,000 miles or so. This doesn't create a rough running situation or anything noticable, but when I put in new points I can notice a bit more pep. I end up changing them about every 5,000 miles along with the condenser. I don't mind; it gives me something to tinker with, and I can get them cheap (ahead of time) on eBay. I guess the electronic ignition would pay for itself after about 30,000 miles, and I assume it would not degrade with mileage as the points do, but if it ever breaks it would probably leave you stranded. Points don't seem to present that risk. Ed
  • maddogKZ
  • maddogKZ's Avatar
13 Mar 2008 00:05
#199844
id opt for the dyna s igniton, but if you do make sure you go with the dyna green coils as well.
  • N0NB
  • N0NB's Avatar
13 Mar 2008 04:51
#199851
The Dyna S also works well with the Accel coil kit.
Nate
  • Bluemeanie
  • Bluemeanie's Avatar
13 Mar 2008 05:52
#199855
After installing the Dyna S, I couldn't believe how faster it started! Before with choke on, hit the starter button and it would crank about 3-4 seconds before lighting off. Now, it lights off in about 1 second. I was so impressed I showed my wife over and over again. She just rolled her eyes and said "that's nice dear" It starts easier, idles smoother and accelerates smoother.
  • mikemac01
13 Mar 2008 18:28
#199956
How hard is this conversion to do and set up. I also see most guys went with the coils also. I see it will work with the stock ones what is the difference. I am also having trouble posting a picture how is it done on this site, Thanks
