Stuck on valve seals
- Scatdrat
- Constructing Scat Rat out of a 78 650D SR
11 Mar 2008 17:14
OK, I have pulled off the tappets & shims, split keepers, spring retainers, both sets of springs and the valves, but for the life of me I cannot get the valve oil seals and spring seats to do anything other than turn. Is there a special tool or trick to this? I have a new set of Viton oil seals that I really want to put in but I'm pretty stalled out here.
~Lost in the woods
~Lost in the woods
Scat D Rat
'78 KZ650 D1A SR
'78 KZ650 D1A SR
- kawsakiman
Re: Stuck on valve seals
11 Mar 2008 20:02
use a pick on the seals and a magnet on the seats.
or a pair of needle nose pliers if your careful.
just be sure to lube the new ones with a light coat of oil and make sure they are seated right.
- bountyhunter
11 Mar 2008 22:51
I think the flat seats are basically round washers and they "stick" because of liquid surface tension of residual oil. You could try:
Take acetone spray (brake cleaner) and hose the living crap out of them to get every bit of oil off.
Then use double sided sticky tape on the end of a pen or pencil and try to stab it to the outer edge of the washer and try to lift it loose.
I had to do that to get the lifters to come out of my head, and I was able to drag them out that way.
- Scatdrat
12 Mar 2008 03:08
I tried needle nose pliers but was afraid of scratching the valve guide, so I pulled on just the rubber to no avail. Maybe a razor to cut up the side of the seal? Anywho, the new ones will just press in or will I need to tap on them?
Scat D Rat
'78 KZ650 D1A SR
'78 KZ650 D1A SR
- Mcdroid
- Gone Kwackers
12 Mar 2008 03:17
The valve stem seals you basically ruin by pulling off with a needle-nose...don't be gentle:) the spring seats will come out with a small automotive magnet (the type with a collapsible handle). The new viton seals merely press on (with your fingers), and rather easily at that.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- BSKZ650
12 Mar 2008 05:50
sometimes they can be a pain to get off, I have even had to use a small file to cut into the seal then pry it off
77 ltd1000, current rider
76 kz900, just waiting
- Sandy
- Fly High,Tony
12 Mar 2008 08:11
Use a dental-pick.You can get them at most auto-stores.They usually come in a kit,and one of them will be hooked...use that one to snag the edge of the seal...and pick away.
And yes,they will fall apart as you pick at them,but don't worry,because You DO have new ones,which is good.
As mentioned...don't be too gentle.
Just be sure to clean up that area before re-assembling.
1977 KZ1000 A-1
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
12 Mar 2008 11:07
Yep, get a pick set. Get the hook in from the bottom and they should pull right out. Then use the magnet for the seats.
West Linn, OR
- APE Jay
12 Mar 2008 11:25
If you don't have the seal pulling tool, you can just use a needle nose pliers. Stick one side through the hole in the seal then pull it off to one side and push it down the outside of the guide. Then close it and pull the seal right off.
Jay
Jay
- Scatdrat
12 Mar 2008 15:58
WOW Thanks guys for all the replys. I just so happens I do have a pick that will work. Strange I didnt think of using it. More project pics on the way...
Scat D Rat
'78 KZ650 D1A SR
'78 KZ650 D1A SR
