No oil pan gasket?
- seanof30306
No oil pan gasket?
11 Mar 2008 01:50
Do you have to run one, or will it be ok to just use silicone?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
Re: No oil pan gasket?
11 Mar 2008 02:48
Would recommend using a new gasket to better assure against leaks and probably having to again R/R the pan.
Wonder if this assembly used any gaskets. :lol:
- OnkelB
11 Mar 2008 13:50
I´d recommend a gasket too - and in my mind silicone does not belong in a motorcycle engine, ever.
77 KZ 650 B1, 82 GPz 1100 B2.
- bountyhunter
11 Mar 2008 13:57
They sell a permanent bonding agent called yamabond that would work, but be a bugger to get off. I recommend you go to Auto Zone and get some of their 1/32" thick gasket material that is the rubberized fiber material. I recall the paper had "N8904" on the back and was made by Interface Solutions. I used it for the valve cover, oil pan, and cylinder base gasket. Works great. Trace one out and get after it with an X-acto knife. If you screw one up, cut another. The paper is cheap.
- RonKZ650
11 Mar 2008 14:36
You're more talented and patient than I am. Just bite the bullet and get a gasket through Kawasaki, and don't forget the 3 (I think) rubber seals that seal the pan to the engine too. They will leak if you don't replace them. Don't mean anything bad here, if you can make your own gaskets that's great too.
bountyhunter wrote:
- bountyhunter
11 Mar 2008 22:46
RonKZ650 wrote:
You're more talented and patient than I am. [/quote] Maybe not, I just don't like being gouged. My local Stealer charges about $80 for a valve cover gasket. Didn't even price the oil pan.
If I am going to pay that kind of money to be abused, it better be by a beautiful woman in high heels and leather....
- seanof30306
11 Mar 2008 23:14
I'm not trying to be argumentative, but I am curious. Why wouldn't something like Permatex #598 RTV work? I've ised it on cars before with no problems, but those were steel pans to cast iron blocks. Is there something about aluminum to aluminum that creates a problem?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- seanof30306
12 Mar 2008 04:03
Thanks a lot, dude. I ordered one.
There's two left, if anyone needs one.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- ronjones
12 Mar 2008 06:12
A little trick, I've been using, is to scan whatever gaskets I buy, into the computer. That way, if I need a new gasket, I can print it on the gasket material and then cut out, using scissors &/or razor.
- kzwolfsr
12 Mar 2008 06:49
You must have a big scanner!
Original man of the Caribbean
12 Mar 2008 10:29
Was the dealer wearing a gun and mask? I would never go back to that dealer!
Here's aftermaket gasket from Z1E
Aftermarket Gasket
Here's genuine Kawasaki from Ron Ayers (plug in part number 11009-1983 I think)
Gasket
Aftermarket Gasket
Gasket
