Compression Ratio for KZ1000?
  • WTF!
  • WTF!'s Avatar Topic Author
10 Mar 2008 15:51
#199389
Just a quick question guys: what is the compression ratio for a stock 77 kz1000?
Currently porting a head and the guy wants to know...
Thanks for the replies.
Auckland NZ
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Compression Ratio for KZ1000?
10 Mar 2008 16:01
#199393
It's nice and high at 8.7:1 according to my OEM S/M published in 1981.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • WTF!
10 Mar 2008 16:27
#199407
Thanks Doug, I did a search in the database buy couldn't get the system to work. Appreciate that a lot. Cheers!
  • Hollywoodmx
  • Hollywoodmx's Avatar
07 May 2014 07:10
#631649
StreetfighterKz wrote: It's nice and high at 8.7:1 according to my OEM S/M published in 1981.
Later, Doug
I was surprised by this..who needs turbo pistons with this compression..lol.
What can one get away with increasing the compression with an oil cooler? 10:1? 11:1? Also happen to know the numbers it makes with higher compression?
I'm just curious.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • steell
  • steell's Avatar
07 May 2014 13:02
#631686
An increase in compression alone, doesn't do much for you, maybe a couple of hp or so if you're still running pump gas. Compression increase, like most other mods, does not do a lot by itself, it needs to be combined with other mods.
Compression increase calculator by Bruce Bowling
The following user(s) said Thank You: 650ed, PLUMMEN
07 May 2014 13:21
#631688
Very interesting. So if I bump up the compression ratio on my KZ650-C1 from the stock 9.5 to 11 my peak hp will jump from 64 to 66. Certainly not much of a gain considering the costs and risks associated with boosting the compression ratio. This helps illustrate why the factory didn't bother with high compression ratios when the bikes were made. Ed
  • GPzEric
  • GPzEric's Avatar
07 May 2014 16:41 - 07 May 2014 16:43
#631717
"This helps illustrate why the factory didn't bother with high compression ratios when the bikes were made. Ed "
That decision didn't have anything to to with HP, it was to make sure those things would run on whatever knocko-special gas you poured into them without pinging. Put a cam with more duration, and more displacement, and the increase in compression does a lot more for you.
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
Last edit: 07 May 2014 16:43 by GPzEric.
The following user(s) said Thank You: PLUMMEN
  • LarryC
  • LarryC's Avatar
07 May 2014 16:59 - 07 May 2014 17:01
#631721
Compression helps puts the "crispness" in the throttle response. That equates to better acceleration. I've run and built a lot of KZ street motors with 190 - 200 PSI on high test pump gas.
Squeeze is a good thing....as long as it's the right amount for the right application.....ask your girlfriend / wife if you don't believe me :silly:
Larry C.
Last edit: 07 May 2014 17:01 by LarryC.
  • zukdave
  • zukdave's Avatar
07 May 2014 17:50 - 07 May 2014 17:54
#631727
Alot has to do with head design a more eff. head will
allow a higher c/r.
Look at a Gen 2 Busa or ZX14 their around 12 -14 to 1
and will live all day on ten pound's of boost with the right tune.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 07 May 2014 17:54 by zukdave.
  • GPzEric
  • GPzEric's Avatar
07 May 2014 19:33
#631741
"..ask your girlfriend / wife if you don't believe me"
That's an advantage of having a sheep... no complaints
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
1983 GS1100E
  • LarryC
  • LarryC's Avatar
07 May 2014 19:44
#631744
GPzEric wrote: "..ask your girlfriend / wife if you don't believe me"
:laugh:
Larry C.
  • CrazyDuck
  • CrazyDuck's Avatar
07 May 2014 20:26
#631748
zukdave wrote: Alot has to do with head design a more eff. head will
allow a higher c/r.
My Aprilia is at 13:1 and that little bugger has some serious bite to it. The throttle response and crispness of that engine is outrageous! Detonation isn't an issue unless you decide to use low octane piss fuel or run it lean.
It is never just one thing that will give you a lot of power other than boost or nitrous.
Compression adds crispness and response, removing excess weight from the bottom end adds more crispness and response, cams always help but really work well with some head work, and carbs make a huge difference once the head can flow enough to take advantage of it.
Power takes time and money. We all wish it was easy and free but it isn't!
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
