Piston Gap Clearance
- jtgraha2
10 Mar 2008 06:32
Hey,
I've got a 1977 KZ750 Twin that is getting a +1mm rebore. I was wondering what the recommended piston cylinder clearance should be.
Thanks,
Jon
Thanks,
Jon
- steell
Re: Piston Gap Clearance
10 Mar 2008 09:05
I don't have my manual handy, but the standard formula is .001" per inch of cylinder bore.
Since you are doing this, surely you have a manual handy to look it up?
I think it's .0015-.002" on each side, .003-.004" total, but I'd look in the manual to make sure.
- mark1122
- Keep twisting it
10 Mar 2008 10:17
that sounds pretty loose Steel. i would think .001" to .0015" total would be better.when they say per inch of bore they are usualy talking about ring end gap.(.003" per inch.of bore)
My 1135cc has .0015" after many miles and my 1327cc has .0025" after many miles.
the manual will say somewhere.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- steell
10 Mar 2008 12:17 - 10 Mar 2008 12:32
Ok, I don't have the 750 twin manual handy, but I do have 1000J manual and 750 four manuals handy.
100J piston to cylinder clearance .043mm - .070mm, that's a little over .001" - .00175"
KZ750 .040mm - .067 mm, that equals .001"- .00154"
Notice that the 1000 has more cyl to piston clearance than the 750? That's because the 1000's have bigger bore, and since the 750 twin has an even bigger bore, I'll stand by my original figures.
But the manual has the final say
Oh yeah, piston ring end gap.
KZ750 .008" - .027", that's almost .003" per inch of bore, but I sure wouldn't run them that close (.008" ) especially in an air cooled motor, I'd use a minimum of .020".
By the way there have been some tests of various ring gaps on a dyno, there were no detectable differences in hp between .015" and .040" ring end gap.
The guy that's racing the 750 twin runs .0005" piston to cylinder clearance, but he is running coated pistons in Nikasil coated aluminum sleeves, not iron sleeves
Last edit: 10 Mar 2008 12:32 by steell.
- bountyhunter
10 Mar 2008 13:32
jtgraha2 wrote:
piston cylinder clearance: 0.043 - 0.070mm (standard)
Ther is no min/max or service limit spec
This is your lucky day, I have the factory manual for the 750 twin.Hey,
Thanks,
Jon
- bountyhunter
10 Mar 2008 13:32 - 10 Mar 2008 13:50
server lockup duplication
Last edit: 10 Mar 2008 13:50 by bountyhunter.
- bountyhunter
10 Mar 2008 13:49
steell wrote:
Unless the flu has made my brain goofy, I thought that .043 - .070mm would be about .0016 - .0028" ?
I recall you always multiply by 4 and scoot the decimal point.
- steell
10 Mar 2008 16:35
bountyhunter wrote:
Well, I said "a little over" :lol:
I was talking to my sister on the phone, helping her with a computer problem at the same time I was typing the post, guess I'm just getting to old to multi task
steell wrote:Ok, I don't have the 750 twin manual handy, but I do have 1000J manual and 750 four manuals handy.
- bountyhunter
11 Mar 2008 14:08
jtgraha2 wrote:
Just metioned it because I had a cow when I checked the clearance of my freshly bored cylinder at the TOP instead of the bottom of the piston.....:laugh:
BTW, the specified clearance is at the widest part of the piston which is the bottom of the skirt. The piston tapers to the top and you will likely see about .007" piston to cylinder gap at the very top if the clearance is to spec at the bottom.Hey,
Thanks,
Jon
- jtgraha2
11 Mar 2008 19:03
thanks once again for the help...can't wait to get to put the new engine together.
