- Thank you received: 2
what valve clearance would you use?
- jimmybon
would you use a more closer gap or wider gap on either the inlet or the exhaust
bike: gpz810, std valves, std cam, rs34 mikuni's, k&n pods, vance and hines, street/track bike
inlet exhaust
close close
med med
wider wider
or a combination
were close is .08-.11
and med is .12-.15
and wider is .16-.18
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
- steell
Every 500 miles or less= run them close
Every 5000 miles= Run them on the large side.
Max power means minimum clearance, but you'll have to stay on top of them.
- Thank you received: 2829
- jimmybon
How often do you want to check/adjust your valves?
I suppose i'm looking for max power, I just can't get around the theory of how each way works
if the clearance is large then would'nt that give higher compression and in turn mor power, and smaller gaps would allow more gas in, any comments?
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
- steell
As far as compression goes, it takes time for air to fill the cylinders, and the higher the rpm the less time is available for the air to flow into the cylinders. increasing the clearance reduces the time available, thus reducing the amount of air into the cylinders.
You "may" pick up a little low rpm torque, but it's going to decrease mid and high rpm power. Good for a tractor, not so good for a high rpm four cylinder motorcycle motor.
Here is an example from a Car Craft article:
Original lash was at .020"Once the motor cooled down enough for safe disassembly (about five minutes), we pulled off the rocker covers and Brul relashed the valves to achieve 0.030 inch of clearance. A few pulls told us we&'d lost about 9 peak horsepower but gained a bit of low-end torque, exactly the result you'd expect if we'd installed a slightly smaller-duration and lower-lift camshaft.
www.carcraft.com/techarticles/valve_lash/index.html
- bountyhunter
- Thank you received: 337
I would set them at .12 - .15. This would allow minor changes (plus or minus) without putting the clearance out of spec. That's where I set mine in 1977 on my KZ650C1 and they are still within spec (although very slightly wider) after 46,000 miles. Ed
The factory spec on my 750 is 0.05 - 0.1 mm (.002 - .004" ). I try to keep them 0.075 - 0.1mm (.003 - .004" ), but would not care if one wandered up to .005".
- jimmybon
The 810 engine that i have has not changed much in 25,000km as well, and have opend if anythingThat's where I set mine in 1977 on my KZ650C1 and they are still within spec (although very slightly wider) after 46,000 miles. Ed
So if i was to set the clearances within the recomended range .08-.18 then if 1 valve is .14 then i'll drop that to .09 , within the range, and if 1 valve is .13 then I'll leave it and check them again in 2000km (in the endless search for more power)
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
- jimmybon
I'v been doin the shims for over 30 years on 9's and 650's
and have mostly left them if they were anywhere in the range but now with more time on my hands I can experiment a little. cheers
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
- steell
That's really unusual, normally the valve clearances on shim type valve trains close up over time, never seen the clearance increase.
Either the bucket or the cam is wearing, or you have deposits on the valve seat or face, that's the only reasons I can think of for the clearance to increase.
- bountyhunter
Yep, been there. Valve stem seal fails, oil runs down and bakes onto the valve seat. Over time, the gap does grow (and the compression drops because the buildup is not symmetric).650ed wrote:
