Exhaust too quiet!
- seanof30306
Exhaust too quiet!
07 Mar 2008 21:16
'79 KZ650 B3
MAC 4-1
Was running it with no baffle. Sounded absolutely awesome, but, it was a little too loud.
Bought a new baffle from Mac. Now it sounds like a salad shooter. Yuck. Phewey. PFFFFTTTTTTT.
Seems like I saw a post where someone said you could drill holes in the baffle to get better sound. Is that correct? if so, where do you drill them?
If not, is there another solution?
MAC 4-1
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- jordan
Re: Exhaust too quiet!
07 Mar 2008 22:05
know exactly what you are talking about. The header made my bike quieter than my previous stock exhaust with just a few holes drilled in it. First, I took the baffle and removed the sound deadening cloth-like material completely. Then in equal distances drilled 5 holes around the baffle. This gave the bike a nice rumble. I keep the baffle in for normal riding, and when I want it to sound really mean I just remove the baffle completely!:evil:
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- seanof30306
07 Mar 2008 22:53
My baffle doesn't have any sound deadening material.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- KTA
09 Mar 2008 03:00
Yep, you can drill out the backing plate on most baffles. Start with a couple holes 180 degrees apart of about 1/2". Then test. Then add a couple more. Repeat until happy!
Follow my
Evan Fell Cycles: Motorcycle Blog
evanfell.com | twitter.com/evanfell_cycles | flavors.me/evanfell
- seanof30306
09 Mar 2008 06:06
KTA wrote:
I hate to look so dumb, but, I'm not sure I'm following you on the "backing plate". My baffle is one piece. It looks like the internals of a car muffler; a chambered design.
I'm assuming you mean the very back of the baffle; the part visible when it's inserted in the muffler?
Post edited by: seanof30306, at: 2008/03/09 09:12
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
- coppertales
10 Mar 2008 09:09
Yep, the back of the baffle. When you are looking at the rear of the muffler part, from the back of the bike, drill some 1/2 inch holes around the center hole, where the exhaust comes out. I did three holes in mine, equally spaced, and it sounds about right to me.......chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- anarki650
10 Mar 2008 09:21
Did you have to contact MAC directly to buy the new baffle? I'm currently running no baffle on my 77 650 and have kicked this idea around for awhile of getting ahold of another baffle for it.
What part number did you have to order? Or did you just tell them what you had and what you needed and they figured out the rest?
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- seanof30306
10 Mar 2008 10:53
I ordered the one off their website. When I didn't get it after several weeks, I called, and learned the order had not processed, and it was the wrong one, anyway. They sent me the correct one, which was cheaper than what the website showed, as well; around 25 bucks.
It's a beautiful part; powder coated, snugh fit, and VERY quiet.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
