Just to be 100% sure, its plug and play using 1000J engine block, and "fill it up" with 1100GPZ crankcase and gear, isn't it?
I will use the main bearing cap on crankshaft which belongs to the 1000J block. Since the book says that that part is made specialty according to each engine block.
