Loose clutch hub?
  • kxhonda
  • kxhonda's Avatar Topic Author
Loose clutch hub?
04 Mar 2008 20:45
#198463
Just wondering how much if any play is supposed to be in the clutch hub? You can move it a pretty good amount.
1977 Kz650B1 #576th made.
Warsaw, In
  • kxhonda
Re: Loose clutch hub?
05 Mar 2008 12:52
#198556
Is there a wear limit for this? It looks like it could be rebuildable if the rivots were drilled out.
Warsaw, In
05 Mar 2008 13:35
#198565
I would love to feel how much play there is in one that is NOS because for all I know, they may start out with considerable play. They are rebuildable; see:
Clutch Basket
  • steell
  • steell's Avatar
05 Mar 2008 13:55
#198570
As far as I know, no one has found a suitable rubber or other flexible shock absorbing material that can be used to replace the worn out stuff that is OEM.
I suspect that replacing it with bolts/rivets and mounting it solid would lead to a short life for the transmission.
I need a 84-85 GPz750 Turbo clutch basket because the rubber dampers in the clutch basket are shot (the missing pieces were caught in the oil pump screen), and nothing else will work except a 750 Turbo clutch basket :(
Zero play when new, the more play there is the more black bits are in the oil pan.
The Turbo manual specifies the limit for the amount of play (but I don't recall at the moment what it is), and I assume the other manuals would list it as well.
Post edited by: steell, at: 2008/03/05 16:59
