810
  • agawam
  • agawam's Avatar Topic Author
810
04 Mar 2008 20:25
#198459
a brand new wiesco 810 kit arrived today, just had to tell somebody, but not anyone locally
  • kxhonda
  • kxhonda's Avatar
Re: 810
04 Mar 2008 20:38
#198461
I am waiting on mine now. Can't freaking wait!!
1977 Kz650B1 #576th made.
Warsaw, In
  • steell
  • steell's Avatar
Re: 810
05 Mar 2008 08:59
#198519
I'm waiting on a set of 810 Wiseco pistons myself :)
  • cafekz750
  • cafekz750's Avatar
Re: 810
05 Mar 2008 09:16
#198525
I am curious as to what the total estimated expenditure will be for upgrading to 810cc.
So, if the bike to start with is in perfect running order; is it just the kit and outsourcing the boring of the cylinders? Anything else hidden in there? I am wondering how much of the "extra" parts I have laying around here I need to sell...B)
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
  • Jay_G
  • Jay_G's Avatar
Re: 810
05 Mar 2008 12:43
#198555
base gasket, cam cover gasket(pricey) o rings on the top and base of the barrels, there is a couple of rthe oil restrictors and a couple on 2 of the studs. shave the head, i knocked 30 thou off mine just started cutting into the edge of the valve seat insert and apparently it realy wakes it up but i didnt have anything to compare it too beforehand, mine lifts the front wheel in first with just throttle in a very untuned state. look at a rejet and maybe some pipes.
  • APE Jay
  • APE Jay's Avatar
Re: 810
05 Mar 2008 21:52
#198647
The piston kit and boring the cylinders runs $591.00
Jay
  • agawam
Re: 810
06 Mar 2008 18:47
#198819
I have most of what I need, down to bore job an time, and making a few decisions as to which cylinder head and carbs, got a few 650 heads and one 750 head, aftermarket cams around .400 lift and 284 dur or GPZs
  • Ituen
  • Ituen's Avatar
  • Rider
Re: 810
08 Mar 2008 12:48
#199071
Who's porting your cylinder head? Which one are you going to use the 650 or 750 head?
1982 KZ750 E
Kawasaki Rider
  • agawam
Re: 810
09 Mar 2008 20:25
#199231
I don't know if I will port the head, I'm thinking about trying to keep some kind of mid range, if I use a 650 head the comp ratio will be higher, smaller ports and valves will keep the A/F speed up for a better mixture and a bit more mid range, the 750 head will give a bit lower compression and slower A/F speed, will sacrifice some mid range, a ported head may give more top end but might make it difficult to ride in traffic, I haven't really decided yet, but if I port one I will probably do it my self, just a basic port and pocket clean up, I have a bunch of cash in it now and I have a few other bikes(6) and a chevy
  • jordan
  • jordan's Avatar
Re: 810
09 Mar 2008 21:10
#199238
Just finished an 810 build myself. I chose to slightly port the stock head. Had valves refaced, with gpz cams up top. Should be a pretty potent little motor. I am still saving for my full dyna ignition before I can fire it up. I will let you know how she rides!
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
