KZ750B2 vs. KZ750 Twin CSR LTD Engine Differences
  • jtgraha2
  • jtgraha2's Avatar Topic Author
01 Mar 2008 15:32
#197795
Hey,
I've got a 1977 KZ750B2 Twin and was wondering if a KZ750 CSR Twin LTD model piston and rings will fit.
It seems like there are no internal engine differences. It has the same 78X78mm bore and stroke.
Anyone know if it'll fit?
Thanks so much!
  • Becker
  • Becker's Avatar
  • The Doctor Will Rise Again
Re: KZ750B2 vs. KZ750 Twin CSR LTD Engine Differences
01 Mar 2008 15:43
#197797
Ya they use basically the same everything for internals. the only thing that you should worry about is that the engine has a different cam in it that would make the valves kiss the pistons without enough piston relief but as long as your current pistons look the same on top as the replacements your golden. Make sure to post pictures your project is done, I love to see what others are doing with this bike.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
