Blown rod bearing!
  • steell
  • steell's Avatar
Re: Blown rod bearing!
07 Mar 2008 17:44
#198981
The rods have to have horizontal play (side clearance) otherwise they will self destruct.
That's also how the oil gets on the cylinder walls, it gets slung up there after oiling the bearings.
  • Scatdrat
  • Scatdrat's Avatar Topic Author
  • Constructing Scat Rat out of a 78 650D SR
09 Mar 2008 18:18
#199205
Well, I reached bottom of the the case. Time to clean, inspect and rebuild. Notice all the metal flake in the oil on the bench. I should have taken a pic of the oil pan, YUK!
Scat D Rat
'78 KZ650 D1A SR
  • Scatdrat
09 Mar 2008 18:20
#199207
Scat D Rat
'78 KZ650 D1A SR
  • Scatdrat
09 Mar 2008 18:25
#199208
Here you can see the deformation of the crankshaft. I miced it to be 1.4mm out of round.
Scat D Rat
'78 KZ650 D1A SR
