Blown rod bearing!
- Scatdrat
- Constructing Scat Rat out of a 78 650D SR
Scat D Rat
'78 KZ650 D1A SR
- Scatdrat
- otakar
cgi.ebay.com/ebaymotors/Kawasaki-Z1-KZ90...5QQitemZ250080563966
Post edited by: otakar, at: 2008/03/01 18:20
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Thank you received: 2829
- kzwolfsr
- Thank you received: 16
Original man of the Caribbean
- Scatdrat
Scat D Rat
'78 KZ650 D1A SR
- otakar
I have some bad news for you and some good news for you. I did find out that the stock pistons for that bike are not available any more NEW. They are also NOT exactly the same as the 1300 pistons, but the 1300 pistons WILL work. The 1300 pistons have a lower dome on them because of the longer stroke of the 1300. This will mean that the 1300 pistons will have lower compression in your bike by about 3/4 of a point. The other good news is that I should have enough pistons in exilent shape to provide you with all four. All I would have to do is clean up the other three. O your other choice is that you might be able to pick up this set for a song.
cgi.ebay.com/ebaymotors/Kawasaki-KZ650-K...dZ1QQsspagenameZWDVW
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- OnkelB
- Thank you received: 80
Since you have the cases apart, just hogg out the cylinder sleve pockets in the upper case and drop in a set of 750 jugs and pistons.
Just a heads up: this will only work with a set of jugs off a 1980 750, later 750 jugs do not have the provisions for the idler sprocket shafts and won´t work with the single roller cam chain setup on pre-81 650s.
77 KZ 650 B1, 82 GPz 1100 B2.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- OnkelB
Post edited by: OnkelB, at: 2008/03/02 12:25
- steell
