Supercharger pressure?
  • Scatdrat
  • Scatdrat's Avatar Topic Author
  • Constructing Scat Rat out of a 78 650D SR
29 Feb 2008 16:01
#197597
Does anyone know a safe operating pressure to run a belt fed supercharger into a KZ650 rebuilt all stock?
Scat D Rat
'78 KZ650 D1A SR
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Supercharger pressure?
29 Feb 2008 16:43
#197599
sorry i dont know . if now 1 can help here, u can try dragbike.com Good luckB)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • PLUMMEN
  • PLUMMEN's Avatar
29 Feb 2008 18:27
#197614
if you are running cast pistons id say to underdrive it.might i also suggest a good set of main studs and center cap support;)
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
29 Feb 2008 18:45
#197618
Ball park estimate...
Atmospheric pressure is about 14.7PSI at sea level and 70 degrees. Your stock compression ratio is about 9:1.
You can go to about 11.5:1 on pump gas with carbs and care with ignition timing. Approx 11.5/9 increase in ambient pressure will give you the same internal pressure as you'd get with 4lb boost.
You can increase boost with a more knock resistant fuel.
IMO 6lb would be it without careful(computerized) fuel and ignition management.
No practical experience to share. I'm still looking for a steal on an M45 :-)
Set it up and see. You can use an adjustable pop off valve to vary boost while you tune. When done, you can select you final pulley size to give that pressure by using the SC manufacturers or your own RPM vs boost curves.
-Duck
  • steell
  • steell's Avatar
29 Feb 2008 19:04
#197626
What's stock compression ratio, 9.0:1??
Atmospheric pressure is 14.7 psi, so 5 psi would be close to 1/3 additional atmosphere, and 1/3 of 9 is 3, so it seems to me that it would be like having a 12:1 compression ratio.
Seems like that to me anyhow, but I have never bolted a supercharger on anything (at least not yet, would really like to get a M45 though) :D
I type entirely to slow, Duck done beat me to it!!!
But at least great minds think alike, eh :evil:
My excuse is I had to answer a phone call while in the middle of typing my post, and I can't type and talk at the same time :D
Post edited by: steell, at: 2008/02/29 23:58
  • 77KZ650
  • 77KZ650's Avatar
29 Feb 2008 22:24
#197676
i think stock is 9.5. but it wouldnt be hard to drop compression to run more boost. do some work to the combustion chamber to increase flow at low lift and that should also drop compression. its way better than going with a baseplate spacer as that would just make the quench huge when used in this application
07 MDP Rookie of the Year
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
01 Mar 2008 09:31
#197728
6-7psi should be ok.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • Scatdrat
01 Mar 2008 14:00
#197780
OK, so I have a belt driven *blower* ;) that is rated for 38psi @ 8000rpms. So if I drive the pulley ratio down to 6:1 engine:blower, I should end up with 6.333psi. Does anyone have any opinions about running this on a stock carbeurated 650?
Scat D Rat
'78 KZ650 D1A SR
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
01 Mar 2008 14:24
#197786
The pressure the blower makes will depend, among other factors, on the engine you intend you use it on. It might make 38psi flat out against a sealed box but whether it makes that on a motorcycle engine is another matter. It's not unusual to run a blower at half engine speed or thereabouts though.
If I was going to do it on a stock carbed 650, which I wouldn't, but if I was, I'd blow through the carbs by balancing the float bowls to boost. I'd also fit a lockup clutch as the stock one has no chance, even with heavy springs. Other than that I'd just err...ummm...save my money and buy a GPz750 turbo :evil:
760cc - 8.69@162mph
  • Becker
  • Becker's Avatar
  • The Doctor Will Rise Again
01 Mar 2008 16:05
#197803
I like your style. Crazy for horsepower. If you really want to make this supercharger work right do what everyone is saying too and then work the cams if you can get more overlap and duration it will lower the actual compression ratio even though the static compression ratio will stay the same. Also my suggestion would be to ditch the carbs and find a way to adapt a FI system to work. It may seem like alot of work but in my opinion it will make it much more worth it in the end. If anyone disagrees please voice your opinions.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
02 Mar 2008 04:11
#197876
Longer duration cams are a bad idea as increased overlap results in more of the fresh charge being pushed straight out the open exhaust valve. This is why the GPz750 turbo uses KZ650 cams instead of GPz750 cams, the 650 cams are about 30 degrees less duration and work better in a turbo/supercharged application.
If you want to lower the compression on the cheap use a 2mm base spacer.
760cc - 8.69@162mph
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
02 Mar 2008 05:47
#197881
Go buy a book on the subject...
Motorcycle Turbocharging, Supercharging, & Nitrous Oxide by Joe Haile will give you a base education on turbos and superchargers. You can pick this up on ebay or Amazon for about $15.00
Generally you don't want to use a supercharger on the street - they are very harsh on drivetrain components.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
