Back to normal(abit) 6th gear?
- kzwolfsr
23 Feb 2008 20:04
Well I posted about my kz1000 having trouble shifting. Its back to normal now a little but I can live with it. I can shift up through all the gears as normal but when down shifting, I have to wave my foot under the shifter lightly as to lift it into position then downshift each time. But hey thanks to the guys that gave me suggestions, they were much appreciated and scarey and I suspect its a spring playing the fool. I it today and man I forgot how much power my 1000 has since I barely rode it during the winter. Question? Am I the only guy here that thinks the 1000's at least need a 6th gear, if my bike can shift into that one?
Original man of the Caribbean
- The Milkman
Re: Back to normal(abit) 6th gear?
23 Feb 2008 21:54
A sixth gear in most of these bikes would be nice, that's where changing the sprocket ratio comes in, but you have to forfeit low speed torque or top speed a little. But, these engines do like to rev..
- kzwolfsr
24 Feb 2008 12:21
What would be the best for fast at less rpms? I have a 16/41 setup. This dont answer. better discussed in chassis. Sorry KZR!
- RetroRiceRocketRider
24 Feb 2008 13:24
Going with a 17/41 or a 16/43 would gain you a higher top speed at lower RPM's, but you will loose some of your bottom end torque leaving from a stop.
I went one tooth larger (16T to a 17T) on my 650 to gain a higher speed and drop the RPM's (roughly dropped about 500 RPM's lower at any given speed) and it worked nicely, and I didn't even notice any bottom end loss either.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
