welded crank
  • meangreenz28
  • meangreenz28's Avatar Topic Author
welded crank
23 Feb 2008 10:22
#196467
Hi, I am currently working on a kz 1000. The plan with it is to make it in to a street/strip bike. Right now I have it completely apart ,and i was wondering where exactly do you weld the crank at? and who can do this, could i take it to the local welding shop or not? Another question, would it be a good idea to have it indexed as long as i have it apart? if so who could do this?
Thanks alot
Post edited by: meangreenz28, at: 2008/02/23 13:23
  • PLUMMEN
  • PLUMMEN's Avatar
Re: welded crank
23 Feb 2008 10:26
#196468
id take it to a shop that has some experiance with motorcycle engines ,im guessig they would be little more carefull than the guy who welds mufflers on the corer;) run a blank drill rod through small end of all 4 rods to make sure its straightB)
  • steell
  • steell's Avatar
Re: welded crank
23 Feb 2008 10:59
#196474
That would be a 17mm drill rod, available from lot's of place for less than $20 for a 36" piece.
  • meangreenz28
Re: welded crank
23 Feb 2008 11:16
#196477
thanks alot for the info, but where on the crank do they weld? is there any pictures of it somewhere. hope fully this isn't too dumb of question.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: welded crank
23 Feb 2008 12:07
#196484
they weld where each cheak meets the journal pins.it is common for the kz1000 cranks to be out of true. the z1's were better. no point buying a drill rod ,the shop will have 1 and they will check it anyway.if u have V blocks and a dial indicator u can check for runnout to see if it is bent(less than .002") and bearing play (less than .002"),also rod ,pin end wear ,and big end side play. may save money, before u ship a bad crank.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • meangreenz28
Re: welded crank
24 Feb 2008 18:53
#196828
Another question, do you just weld the outside one or all of them. Do you have to disassemble the crank?
I found this www.oldkawman.com/okndcranks.html
but it only shows the outside one welded.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: welded crank
24 Feb 2008 20:46
#196850
thats it,gotta be carefull weldig it though;)
  • APE Jay
  • APE Jay's Avatar
Re: welded crank
24 Feb 2008 21:12
#196863
After you are sure it is not out of index, weld about 1/2 inch where every wheel meets a pin. It takes a very small tourch to get into some of them.
Jay
