- Thank you received: 1
750 to 650 ignition parts compatability
- Qdude
- It is all good.
22 Feb 2008 12:25 #196300
by Qdude
77 KZ 650 C1.
77 KZ 650 C1.
750 to 650 ignition parts compatability was created by Qdude
A site member has informed me that he has a 750 motor that he is parting out. I sent back a reply to get the year.
What are the chances I may be able to use the 750's ignition parts i.e. cover, advancer/mounting bolt, rotor, timing plate, wiring and oil pressure switch.
Likely, not likely, depends on year?
77 KZ 650 C1.
77 KZ 650 C1.
- Bluemeanie
- Thank you received: 14
22 Feb 2008 12:43 #196305
by Bluemeanie
Replied by Bluemeanie on topic 750 to 650 ignition parts compatability
According to Kawasaki.com, a 650's breaker plate assembly and advancer will only fit the following...
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
But I would think that the 750 ign parts would fit as they are externally, basically the same motor?
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-F1 (1980)
- Philip Meaney
22 Feb 2008 14:05 #196318
by Philip Meaney
80 750 H1
85 750 Turbo
84 GPz 750
Replied by Philip Meaney on topic 750 to 650 ignition parts compatability
I would think it's a function of the year. I, for one have put 650 ignition pick-ups in my 80 750 LTD.
80 750 H1
85 750 Turbo
84 GPz 750
- rstnick
- Thank you received: 377
22 Feb 2008 17:29 #196359
by rstnick
You will be able to use them.
I first put a KZ1000 elec. Ign on my bike. Just needed to make the pick ups plate smaller to fit. See the KZ1000 elec link in my signature. It explains the wiring etc.
You'll need the IC Igniter as well.
I now have a 650CSR '80s vintage pick up plate in, which is a dirrect fit, of course.
Also have a GPZ750 plate with pick ups, which is the same size.
The 650 and 750's bottom end are basically the same.
Post edited by: rstnick, at: 2008/02/22 20:30
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic 750 to 650 ignition parts compatability
What are the chances I may be able to use the 750's ignition parts?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- loudhvx
- Thank you received: 1616
22 Feb 2008 20:49 #196401
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 750 to 650 ignition parts compatability
For some reason, the latest Kaw electronic ignitions won't fit into the ealier motors. If it has mechanical advance, then it should be swappable. Those can be identified by the round timing plate.
The later style electronic-advance ignitions supposedly won't fit into the older motors because the ignition plate is larger (and no longer round). Apparently the newer motors have a slight difference in the casting of the ignition area on the engine case. I was told this, but haven't personally investigated it myself.
1981 KZ550 D1 gpz.
Other links.
