Need help with part list.
- Qdude
- It is all good.
21 Feb 2008 13:57
My manual is packed up right now (I just moved).
I smashed the right side of my motor where the ignition is this Monday. I know that I need a new dyna ignition unit, but without the manual, I am not sure what else I need to search for.
The aftermarket ignition piece is smashed and the center shaft is bent up as well. I imagine that I will need to pretty much replace everything from the block out.
Does anyone have the parts that they can sell me?
I am traveling by 35 mph scooter now 25 miles to work.
Scooter,..... the shame.....
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- loudhvx
Re: Need help with part list.
21 Feb 2008 14:25
If the case is ok, then you probably need a cover, advancer/mounting bolt, rotor, timing plate and wiring. I think the oil pressure switch may be in there too. If you get a new dyna S, it comes with the rotor, timing plate, and wiring.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Qdude
- It is all good.
21 Feb 2008 16:23
You da man !!
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
