oil fitting conversion.. help
  • eel
  • eel's Avatar Topic Author
19 Feb 2008 20:23
#195731
got a bigger cooler from a newer z750 and the old lines dont match up. Old cooler had AN style fittings, new cooler has oring type compression fitting.
Is there a brass fitting made by someone that will change the oring style to AN style?
here is a pic of the old cooler and the new line (chrome-it is not long enough to reach the motor) and the old line (bottom)
Post edited by: eel, at: 2008/02/19 23:24
1984 GPz750
2007 ZX6R
53-Racing.com - My Website
My GPz
  • bountyhunter
  • bountyhunter's Avatar
Re: oil fitting conversion.. help
20 Feb 2008 09:47
#195813
This is when you wish your brother-in-law was a plumber..... or maybe a machinist.
  • The Milkman
  • The Milkman's Avatar
20 Feb 2008 10:18
#195821
Is it possible to just switch the fittings between the coolers or are they soldered in place?
If they are soldered in place take it to a radiator shop and see if they can do it.
That old line from your angle looks like a simple flare fitting, although it may be double flared like a brake line and your friendly neighborhood mechanic should be able to make a new line up for you if you don't have a flaring tool. This is providing that the fittings came be switched to begin with.
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
20 Feb 2008 12:19
#195861
could you not drill a larger hole using a drill press in the female side(the connecter on the oil cooler) the same diamiter as the male side, they should join then no?
way way way too many bikes to list and the list still gets longer.
  • kzstreetfighter71
20 Feb 2008 12:24
#195864
  • eel
20 Feb 2008 12:59
#195873
i dont think you got it.
i want to convert AN style female to female type oring.
1984 GPz750
2007 ZX6R
My GPz
  • BSKZ650
  • BSKZ650's Avatar
20 Feb 2008 13:14
#195878
I dont know of any adaptor that will make that work, you may have to change out the lines, should be able to get some nice ones made with the right fittings at a hose shop
77 ltd1000, current rider
76 kz900, just waiting
  • loudhvx
  • loudhvx's Avatar
20 Feb 2008 20:47
#195958
You could try Aeroquip if you can get a hold of them. I haven't dealt with them in years.
www.aeroquip.com/index.asp
