Rod bearings
- Bluemeanie
- 77KZ650
Re: Rod bearings
22 Feb 2008 08:48
the z650 was just the european version(different paint ect). same motor
07 MDP Rookie of the Year
- Dirtybiker
Re: Rod bearings
24 Feb 2008 01:41
Thanks for the heads up on the manual. I will try and get the winning bid. If not that one there are others I found. Thanks again Scott
- Lorcan
- Speed Loony
Re: Rod bearings
24 Feb 2008 02:43
On the turbos we measure it all up, plastiguage it, then stick the slackest bearings in and run it :laugh:
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- themachine
Re: Rod bearings
24 Feb 2008 10:47
i dont pull a bottom end apart unless i have to, only if its knocking or for new bigger pistons, i belive that the more miliage on the engine the more the bottom end will be broken in to the point where you can beat on it all day long and not have it throw a rod.
i had an older s-10 with a 2.8 v-6 5 speed that had 150K on the clock, it had bad valve seals but i stuck a cam in it and tweaked the distributor to spin it to the moon and it never blew up. :evil:
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
