Baffled
  • HOGEATER
  • HOGEATER's Avatar Topic Author
  • Been riding 2 wheels since 1965,
Baffled
15 Feb 2008 14:25
#194780
I'm having problems getting my timing set.
I have a 79 KZ1000LTD I've set the timing marks on the cams to the crank marks but if rotate the engine crank 360 the marks are 180 out, rotate 360 again they are on the marks??? WTF Is some thing broken or is it me.
HOGEATER.
  • The Milkman
  • The Milkman's Avatar
Re: Baffled
15 Feb 2008 14:45
#194781
No, that's as it should be , the cams turn once for every 2 revolutions of the crankshaft.
  • bountyhunter
  • bountyhunter's Avatar
Re: Baffled
15 Feb 2008 14:46
#194782
HOGEATER.
The first time I rebuilt the top end on my KZ750 I noticed the exact same thing: I very carefully aligned to TDC and then put in the cams and made sure the arrows were pointing outward and horizontal to the top of the head surface (as the book says).
Some time later after I had been working on other things, I decided to recheck and rotated the engine back up to TDC and noticed the cam arrows were 180 out (pointing inward). So, I took it apart and realigned the cams.....
Then I realized they were correct either way. There are two TDC alignments on each four stroke cycle, because the complete cycle takes two revolutions. You can set the cams to the line marks on either TDC, it makes no difference. If you rotate the engine one revolution after alignment, the cams will then appear to be 180 out of spec.
Post edited by: bountyhunter, at: 2008/02/15 17:50
  • HOGEATER
Re: Baffled
15 Feb 2008 15:02
#194785
Thanks for the quick answers , now I just need to put the rest back together so I can ride..
HOGEATER
